Omega Juicers 8006 Nutrition Center Hd Juicer - Chrome/ Black Logo
Question about Omega Juicers 8006 Nutrition Center Hd Juicer - Chrome/ Black
Why does rotation go in the wrong direction?
Attachment stuck
try to rotate top part while you pushed it down with two hands, somme one must help you to handle basement with forces in oposite direction, work smoth dont give too much force in the samme time or you are going to broken top part, put force in ascending
How can I remove the serrated drive coupling from a Krups F577 blender so I can replace it?
Normally they are threaded on, to remove them they need to be shocked to turn in the same direction as they turn when operating. A solid screwdriver and large hammer to whack it to turn in the normal direction it rotates when being used.
Aug 08, 2013 • Blenders
The coupling to the motor is loosely rotating on the motor shaft. Has the threads on the coupling worn out. it is a breville optiva cbl6 blender
The coupling bush wear out in due time and must be replaced. if there is a wearing detected it must be changed or it will result in failure of the bush/ bearings of the motor and jar. You will need to remove using anti clockwise direction, Get the correct spare part from the dealer to replace. Good day
Aug 16, 2010 • Blenders
How to unscrew the damaged rubber driver gear so that I can screw on the new one.
This isn't a 'generic' problem since it is doubtful that all brands are the same. You need to include make and model when asking for help.
Just generally; note the direction the motor rotates when running and try removing the damaged drive gear by turning in the same direction while preventing the motor armature from moving. This latter problem may be tough on some motors and avoid digging into the windings with a screwdriver or other object. It could be a left-hand thread which is always confusing (and unnecessary most of the time).
I'm surprised to read that anyone is attempting to repair an item that is fairly inexpensive to buy new but I wish you success; there is enough junk in the dumps already.
Jun 25, 2010 • Blenders
3helpful
Kitchen Aid Blender - blade not rotating
You will definitely need to change the clutch blade i.e. the black rubber rotating bit. Chaging it on the base unit may be difficult, I would check with your local Kitcheaid repairer for spare parts and repair advice.
Also check the clutch blade on the jug itself.
2helpful
Back to Basic Smoothie Freeze Bades don't rotate
check to see if you can move the blades by rotating the shaft on the bottom of the goblet, sounds like you need a new blade assembly.
you can order the part from their website:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3699&secid=53&linkon=category&linkid=91
14helpful
3answers
Cleaning
You have to hold the button (above the blending jar) down while turning the rotating paddle in the ice hopper. It will eventually catch, then you can unscrew it, take it apart, and clean it. Just be careful not to cut yourself on the shaver blade.
1helpful
Top Omega Blenders Experts
Marvin
Marvin
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Are you an Omega Blender Expert? Answer questions, earn points and help others
