SOURCE: HP photosmart C5280 Manual
Manual here: Manuals
Here is the support page with more documentation: HP Photosmart C5280 All-in-One Printer
SOURCE: brazilian regionalization zone code???
To change the region there is a special report to be printed from the printer from which some numbers are to be taken which belong to the printers firmware these numbers are to be given to HP they ll run an algorithm on it and then it can be regionalized... one printer can only change a region 3 times....
Try
1. Press Setup until Preferences appears, and then press OK.
2. Press until Set Language & Country/Region appears, and then press OK.
You are prompted with a list of languages. You can scroll through the list of
languages by pressing or .
3. Press OK on the appropriate language.
4. When prompted, press OK to select Yes or Cancel to select No.
You are prompted with a list of countries/regions for the selected language.
5. Press to select the appropriate country/region, and then press OK.
6. When prompted, press to select Yes or No, and then press OK.
You can confirm the language and country/region by printing a Self-Test Report,
as follows:
1. Press Setup until Print Report appears, and then press OK.
2. Press until Self-Test Report appears, and then press OK
Thanks.
