Canon PIXMA iP4000 InkJet Photo Printer Logo
A
Anonymous Posted on Jul 25, 2014
How to clean print head on canon pixma ip4300?
SIMON MATTHIAS NG
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 58 Answers
  • Posted on Jul 26, 2014
SIMON MATTHIAS NG
Contributor
Level 1:
New Friend:
Cheetah:
Answers
58
Questions
0
Helped
24006
Points
75
Go to the maintenance tab in the Windows Printer Driver property
5 Related Answers
tom19511
Thomas Christopher
  • 1601 Answers
  • Posted on Nov 02, 2007
SOURCE: no color printing canon pixma ip4300
try this
http://www.usa.canon.com/consumer/controller?act=SuprtKnowledgeBaseAct&fcategoryid=257&modelid=13528
Anonymous
  • Posted on May 15, 2008
SOURCE: Canon IP4300, Yellow prints as green. And all colors prints blue
makklodge:
1. Replace your Ink cartridge with original Ink. (yellow problem is Black catridge problem.
2. Clean your Printer Head using with ISOPROPHYL ALCOHOL.
MrScared
Anonymous
  • 6 Answers
  • Posted on Jun 27, 2009
SOURCE: Canon Pixma ip4300 won't print
penge lhat ng alam muh
Anonymous
  • 91 Answers
  • Posted on Feb 15, 2010
SOURCE: canon Pixma IP4200 started printing regular
Hello first of all are you technical
I have taken the printer head out
boil some water and pour in a cup
take off the 2 screws at the bottom
gentley open the head from the casing**** note if you not gentley it wil brake and U can through the hole head away
then let the white block lie in in the water until the water is cold the trough that out and repeat this step.Boil water again....Wait for 4 to 5 minutes to pass..... then use high copressed air and blow from the underneth so that the presure will force the **** out on the white block side also force some hot water from the litle sifes at the top down and make sure that holes are open
replace the ruber perfectley and the head pease an make sure every thing is propeley dry.Replase the scews .and put it back in the printer.Remember it is also a very filthey and inkey job.Good luck
Col Johnson
  • 118 Answers
  • Posted on May 30, 2011
SOURCE: my canon pixma iP4300 wont print cyan, I have
Unfortunately the problem is in the printhead situated just under where the ink cartridges go. It can be removed by removing ink cartridges and lifting it out from the top. You could try cleaning it or dispersing it in a mil of hot water for 1 minute while holding it. Then dry it, reinstall it and run deep clean again. Unfortunately this does not work very often but you could get lucky.
If not then only alternative is to buy another printhead and they cost more than the printer is worth.
The orange light on pixma iP4300 is flashing 5 times. I have cleaned the printhead (gold contacts) with alcohol PJ
Use cotton swabs dipped in hot water or a mixture of hot water and isopropyl alcohol
Use it to clean the print head and the electronic contacts on each ink cartridge
Once done, allow to dry and try again
If the error still persists, you have a damaged print head which needs to be replaced with a new one
Hope this help!
Not printing yellow
It seems that your cartridge needs replacement. But you can still try this:
remove your color cartridge, dip the head in warm water for about 5 mins.
remember, dip only the head. it's the part where ink flows out. be careful not to touch or wet the gold contacts on the side of the cartridge.
1helpful
2answers
Canon ip4300; new printhead and PGBK ink cart but it won't print
call ok canon 800 number..their better than India CAll centres.
Canon pixma ip4300 - magenta ink is recognized but not printing
Take the print head out of the machine and sit it in a saucer of very hot ( just off boil) water about 10mm deep for a minute. Take it out and sit in on a pad of paper towel to dry briefly before returning it and the cartridges into the machine. Give it a deep clean and try again. If still no good, the print head has probably had it.
makklodge:
MrScared
Print head moves but no ink is delivered
try cleaning nozzles.
Mr.Musculo is very helpfull - put the print head in warmed solution (35 grad.celsius)
old marine
old marine
ZJ Limited
ZJ Limited
