Question about Electrolux Freezers
Removing freezer drawer from E32AF75FPS6 - Electrolux Freezers
Frigidaire bottom freezer spills ice when opened and I can't shut the drawer til I fish the ice cubes out.
You might be well served with a general defrost of the unit. But before you do, make sure that the mounting screws on the ice maker are fully in. Then if so, warm the lower surface of the ice maker where cubes are ejected with a hair dryer for a minute or two (medium not high). It could be that extraneous ice is catching the cubes. What does it feel like to the hand?
Mar 02, 2018 | Frigidaire 20.3 cu. ft. Upright Freezer...
How do you remove drawers from craftsman 26" quiet glide middle tool chest?
My Craftsman rolling tool chest has bearing glides. Open the drawer all the way and look at the drawer glides. One each side there is a small black lever to release the drawer from the glides. One will move upward and one downward by pushing on the beveled side and pull the drawer out.
Jan 03, 2013 | Tools & Hardware - Others
Excessive fosting in the freezer compartment
may have a bad drain line heater or a bad defrost heater, thermostat, or timer.
Oct 09, 2009 | Freezers
Cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Frosting & water dripping from freezer in Frost free freezer
Hi, You will find that your problem relates to the defrost heater in the freezer. You will need to take the drawers out and remove the back panel to access the evaporator. There is a foil heater that lays underneath the evaporator and it will need to be changed. Along with the klixon that controls it. This will ensure that both parts are good. Your problem will then be fixed no more water!
Good luck................
Dec 30, 2008 | Freezers
Bottom drawer hard to close
Check the drawer slides on each side for cracks or a screw that has come loose. The drawer should slide in a groove on each side firmly. Hope this helps. JT
Oct 10, 2007 | Miele 3.7 cu. ft. / 105 liter Upright...
Freezers Logo
94 people viewed this question
Top Electrolux Freezers Experts
Dennis Boxerman
washington munene
Level 1 Expert
ray gallant
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
