I need to know fast if my model television can Recieve the QAM setting. Or if there is someway I can program the tv to get it with out a problem. Also does the tv have an issue with that.
Refer its user manual for details. Electro help
SOURCE: Need 3-digit TV remote code--Sylvania 15" LCD HDTV
many of the dish remotes have a "scan" option. This is what the installers use. You'll ned to read the manual. Its a one page explanation.
SOURCE: need to know if my tv is digital or analog?
most new tv's are digital capable...
but here is the trick the convertor box are only for those who don't have cable or satellite service if you use only an antenna to get channels then yes you will need a converter box for each tv that uses only the antenna to get channels if you have satellite or cable service then they don't need a converter box even if they have basic cable they won't need the box there channels are already digital converting now there are a few events that was in anlog but there are being converted as best as possible but you may notice the difference in the pictures betwwen analog (usaully old time movies or show even commercials) Digital (most everything now that are new stuff are digital and even in hd now)...
SOURCE: Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
SOURCE: Need universal remote code for Sylvania TV
Open the battery compartment of the controler and take the batteries out and there should be a phone number there you can call.If it isn't there go on line and find the remote codes you are looking for.
SOURCE: sylvania tv lc220sl1 trying to hook up with dish
We would be happy to help get your picture back. The first thing we want to ensure is that all connected equipment is on.Check what type of cable is used to connect the TV to the receiver. If you areusing a Coax Cable to connect the receiver to TV1, check the receiver'sback panel for the output name. If your receiver has a "TV CH 3/4Out" (non-ViP Receiver): Tune TV to channel 3 or channel 4, backif it is labeled "Home Distribution" (ViP Receiver): Tune TVto channel 62 or 75. If using non-Coax (RCA, Component, orHDMI) to connect receiver to TV1, cycle through the inputs until pictureappears; Most TVs have a "TV/Video", "Input", or"Source" button. We want to ensure that the TV and the receiverare connected properly, please visit this link to for more information:http://www.dishnetwork.com/SupportSection/setup-receiver-totv. Once we havemade sure everything is connected properly, unplug receiver for 10 seconds thenplug it back in, this will reset the receiver. If we are still not getting apicture connect another component (VCR, DVD Player, etc.) to the same TV, usingsame cable, same input, and same channel to see if it works. If you get apicture with the other component give us a call at 1-800-333-DISH (3474) forsome additional troubleshooting. If it doesn't work with the other componentthen replace the cable that was used.
We hope these steps resolve the issue. We want to thank you for being a valuedDISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
