How can I program my COMCAST remote for my Curtis TV?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
SOURCE: remote programming codes
Hey Kashaclysm, try this: www.urcsupport.com
Have your remote handy, have your TV model number handy.
SOURCE: how to program comcast remote with my toshiba 19hlv87
with comcast remote with red ok select switch the toshiba codes are 11256 most likely, other codes are 10154, 10156, 11265, 10060, 10650, 10845, 11156, 11356, 11656, 11704
with comcast remote with grey ok select swithc the toshiba codes are 0154, 0156, 0060
Dale
SOURCE: Curtis International TV remote codes for universal remote
Need a Model number of the back of your TV set for one and the model of remote your comcast company is using there. There are different brands in different place's.
Testimonial: "Comcast RC1475507/02B remote Curtis model LCD2400A"
SOURCE: can't program cable remote to operate tv.
Try code 11801. It worked for me with the Comcast Digital Transport Adapter Universal Remote.
SOURCE: need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
