Question about Zebra Symbol LS 1203 Barcode Scanner
Why my LS1203 scans only first 7 digits of bar code?
I have connected it via Keyboard wedge interface, and it scans only first 7 digits of bar code. I have installed drivers..
Linh Thy
    New Friend:
    Problem Solver:
  • 17 Answers
Head over the url https://www.gmail.com , then Click on Login after creating an account. You will be redirected to the gmail login page where you will be having an option field where you will going to write your gmail username or Email and then hit Enter or press the button that says "Next". In the very next step if your Gmail username or email is correct, it will now ask you for the password of that account. Enter your password there in that field (Keep in mind that: Passwords are case sensitive, you should check each and every character while entering the password and you will need to enter the same password as you chose while the Gmail sign up process).
That's it you will be logged in to your account if the credentials you entered for the account are correct. If you are facing any issues regarding account password or recovery follow our Account Recovery guide.
http://gmailloginup.com/
Posted on Jun 13, 2019
Karl Whisenand
    Genius:
  • 1,554 Answers
You need the configuration barcode chart to set it to the type you use.
Posted on Jul 25, 2014
1 Related Answer
Yogger
Max Quido
  • 117 Answers
SOURCE: I have a Symbol LS1203 but it doesn't read a C39
you would need to set the correct length for the barcode, there are several settings at the page 186 of the Product Manual located here http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
The options are One Ddiscrete Length, Length Within a Range or Any Length. Please select one of them by scanning the approriate barcode.
Posted on Nov 02, 2010
Why does my LS1203 scans only first 7 digits of bar code?
its in the settings youll need a settings barcode chart to change that
Jul 25, 2014 | Zebra Symbol LS 1203 Barcode Scanner
Tip
How do I read Barcodes in Microsoft Excel?
<p>Bar code symbols are composed of a number of adjacent bars and spaces of different widths of pre-defined codes. A barcode scanner is used to read or scan the bar code symbol to represent the information to decode. Once the symbol is scanned by a handheld reading device or another, can then be used by computer software to track inventory and perform other functions. Microsoft Excel is a computer application that use bar code information can make the business perform. <br /> <p><br /> <p>1. Insert bar code scanner to your computer using the "interface cable keyboard wedge". The keyboard wedge interface cable looks like the printer port of your computer, and differs only in that a connection between the scanner bar code and serial number of your computer or USB port. The cable is provided as a peripheral pattern with hand-held bar code scanners. <br /> <p><br /> <p>2. Open Microsoft Excel on your computer after the bar code scanner connected to your computer. <br /> <p><br /> <p>3. Links on the Excel cell to the bar code to enter and bar code scanning to load it into Microsoft Excel. <br /> <p><br /> <p>4. View the data in Excel file is translated into a vision of the bar code information. <br />
on Jun 26, 2011 | Computers & Internet
Tip
Handheld Barcode Scanner service
Do you currently have hand-held inventory scanners?
Although you may not be familiar with Legacy's Technology Services, we may already be servicing your barcode scanners, barcode printers and even POS hardware. Many sellers of extended maintenance contracts have used Legacy for years to perform service on devices covered by their contracts.
Maybe you're looking for a specific hard to find part. Chances are I've got it!
We also carry refurbished equipment if you are in the market.
Give me a call for a quote and to discuss your current needs.
Joe Anselmo
Legacy Technology Services Inc
(630) 622-2018 ext. 418
Email: [email protected]
on Apr 13, 2009 | Zebra LS1203 Bar Code Reader - Handheld...
I wish to connect a bar code scanner to my Keyboard Display Unit for inputting data when printing labels. Can you provide information relating to pin outs, protocols and how to set this up? Thanks
By Keyboard / Display unit I'm assuming your using a PC, thin client or dumb terminal. If you are using a PC then the easiest way to do this is to get a bar-code scanner with a USB interface, no programming should be required with possibly the exception being of adding a "Enter" (CR LR) after each scan.
If you have a dumb terminal then you may need to look at trying to use an RS232 connection (if one exists) or a keyboard wedge solution where the scanner is plugged into the keyboard port along with the keyboard.
In any event pin outs would vary depending upon the scanner you want to use and the device you are connecting the scanner to.
Hope this helps
[email protected]
Mar 02, 2011 | Zebra Eltron LP 2824 Thermal Printer
Symbol LS 9100 does not transmit data
after scanning the defaults barcode you just scan the "Enable LS 9100 Communication" on this manual on the link above.https://docs.symbol.com/manuals/1536503c.pdf
May 11, 2010 | Symbol LS9100 Hands Free
Symbol HotShot LS2106 sounds like it's scanning, however, no data/information is displayed once scanned. Connecting to Windows XP with a USB converted to PS2 cable. Are there reset bar codes available that...
The LS2106 did not support laptop mode so the PS/2 wedge needs to have a PS/2 keyboard attached to the cable. If that does not work I would suggest trying to find a 25-31617-01 Synapse adapter cable and STI85-0200 USB Synapse cable. This would allow you to connect the scanner right to the USB port and it should work without any extra programming. I believe the cost of the two cables (if you have to purchase them new) is almost as much as a new LS1203 scanner with USB cable. At least with the new scanner you would get a three year warranty.
Jul 03, 2009 | Symbol Hotshot LS2106 Handheld
I cannot get my opticon barcode reader to work with my wirless keyboard. I have a Dell computer, and a Microsoft wireless keyboard I have the hand-held CCD Wedge Interface (25-wedge-06 Opticon Bar code...
Hi!
Keyboard Wedge Barcode Scanners are sometimes tricky because they will not operate if the keyboard is physically attached to the Scanners' "Y" cable. A possible solution would be to attach an additional keyboard to the "Y" cable and simply set it aside un-used. (This would allow you to continue to use the Wireless Keyboard; which I assume is USB). I may also be able to program the scanner to operate in a Laptop Mode which would allow you to operate successfully as-is. I would need your exact model number to investigate if this is possible.
Hope this helps!
-Dave
Dave Krause
Founder, Bluesky America's GetOpen.com
720.771.5194 Direct 888.7.GETOPEN Toll-Free
Apr 02, 2009 | Computers & Internet
Need my p470 symbol scanner to auto enter
It depends on whether you are using a keyboard wedge or a serial connection. Use 123Scan or MCL to make a change to the ADF file that tells the scanner what to do. Then you will have to upload the file to the scanner.
Appending an "Enter" to a scanned bar code
(Keyboard Wedge connection)
Scanned bar code data 04843100Criteria 1 Code type = Any
Criteria 2 Code Length = Any Length
Action 1 Send all that remains Action 2 Send Value Keycode = 7013 <Enter> (String field must be empty)
Output after ADF rule 04843100<Enter>
Note: To have an ADF rule applied to all scanned bar codes, leave the criteria unspecified (Code Type = Any and Code Length = Any Length).
Appending a "Carriage Return Line Feed" to a scanned bar code
(serial connection)
Action 2 Send Value String = \0D\0A
Note: Keycode value is ignored when string field is populated.
Output after ADF rule 04843100<Carriage Return Line Feed>
Dec 25, 2008 | Computers & Internet
Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Feb 12, 2008 | Metrologic Instruments Voyager MS9520...
Metrologic 9520 help...Please
Is it 13 digit barcodes you are trying to scan?
Also, does the cable go straight into your till (straight cable) or is it connected to you keyboard via a wedge?
Jan 19, 2008 | Metrologic Instruments 9520 Voyager
Zebra Symbol LS 1203 Barcode Scanner Logo
150 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
