Any 2 cycle oil will not do for an air cooled 2 stroke.
Granted I am not saying that buget 2 cycle oil will cause an imeadiate blow up. But you will get more carbon build up, less protection , higher wear rates. Increased servicing costs.
You need oil specified for air cooled 2 strokes. Marine spec oil is very high quality. But it is not really made for air cooled motors.
Stihl used to get their oil made by Castrol. Not anymore. I don't know the reason for the change.
Stihl now market 3 grades of 2 stroke oil..
Three different specs
Three different levels of protection.
I only use the ultra-spec oil. Fully synthetic.
It costs a little more.
But it costs a lot less than a new chainsaw.
Mixture is 50 to 1 i.e. 100ml to 5 litres of petrol. I don't know (or care) how that is for stuck in the mud non metric countries, like America... sorry guys. I used both systems growing up. Metric is better , easier to understand 90% of the time.
In the workshop we aim for a mix between 40 to 1 and 50 to 1
Motors are nominally (in the laboratory) safe out towards 75 to 1. On modern hi spec synthetic oils.
But I would not chance it. Mix in any other problems lean mix/ poor fuel/ chronic overloading of a saw with a blunt chain etc. You have a recipe for at least accelerated cylinder wear, more probably a heat related seizure.
Stihl recommend 50:1 using Castrol 2 stroke mix
5 to 1 .till its almost smokin
SOURCE: what is the fuel oil mixture for stihl ms660 chainsaw
hello sir, the gas / oil ratio is, 3/4 o/z per quart or 2.6 o/z per gallon of two cycle oil, any two cycle oil will do,this is how i mix mine and never had a problem,it is a good mix.hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ~~
SOURCE: where do I find a operating manual for my STIHL
Don't believe everything you read. Stihl Product Instruction Manuals http://www.stihlusa.com/information/info_product2.html If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck. Lou Thank You for using FixYa.
Your OM can be found here:
This was returned from my attempt:
http://www.stihlusa.com/stihl_ownersmanuals/MS210230250_Manual.pdf
IPLs (parts lists) are proprietary and not available to anyone not a Stihl dealer.
SOURCE: keep burning up piston on
It sounds like you are running lean. Not a lean oil/gas mix but a lean Air/fuel ratio. This engine runs hot as a high performance engine. any air leaks such as crank seals, manifold gaskets or muffler gaskets can give you too much air for the fuel coming in.
Secondly from the fuel side:
Ethanol (curse it) combines with oils that have no nondispersants making a white chalky poweder in the fuel system causing less fuel to mix with air. any blockage or pin hole leak can cause less fuel to be brought into the engine thus less cooling and lubricating.
Your carburetor and fuel filter need to be serviced and adjusted correctly or they will affect the mix.
When done the engine should run no faster than 13,000 rpm top no load speed.
This engine should idle smoothly at 2,500 with no more than 150 rpm change
if the speed is not as listed above when the rebuild is done you need to go back into the machine.
Call up a shop like www.arcolawn.comto get a EDT8 tach. it is well worth the money.
good luck
Joe
SOURCE: I need an owners manual for a Stihl MS180 Chain
Hello Dave;
An OM for your saw can be found at this link:
http://www.stihlusa.com/stihl_ownersmanuals/MS170_180_Manual.pdf
Lou
SOURCE: chain oil leaking on 025 stihl chainsaw
Their is a oil passage that has a plastic plug in it by the muffler. It might be gone like mine is.
