Car Audio & Video Logo
A
Anonymous Posted on Jul 25, 2014
Power loss on my JVC KD-DB95BT
It has been installed by Halfords and it worked initially, but then wouldn't power on. The unit was replaced and the same problem soon occurred. That unit was reinstalled and the same has happened
  • Chris J
    Chris J Aug 03, 2014
    What car was it fitted into? I had the same problem with a BMW Mini with 2 x JVC KD-DB95BT units
Errol Hodgson
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 135 Answers
  • Posted on Jul 28, 2014
Errol Hodgson
Expert
Level 2:
New Friend:
Greenhorn:
Answers
135
Questions
0
Helped
82002
Points
140
With two radio doing the same error normally leans issue at car installation. When power is lost try pressing EJECT to see if you hear a motorized noise. I would recommend to directly connect to a 12v power supply out of car to troubleshoot or send in for review. This will be hard to troubleshoot over internet if this is a car installation issue.
5 Related Answers
informatica
Greg Cann
  • 1114 Answers
  • Posted on Jul 21, 2008
SOURCE: how set time jvc kd g220
Hi - You can download the manual from the link underlined in blue below:
jvc kd g220
See page 10.
Please update the question & let us know if the information given was useful to you - Good Luck!
Anonymous
  • Posted on Mar 02, 2009
SOURCE: jvc kd-pdr30 ipod problems
The Touch will not work with the KDPDR30. I spoke with JVC and their models that will operate the Touch are KDPDR40, KDAPD49, KDPDR45, KDPDR41 and KDG47 the last two have a cable required.
Anonymous
  • 8 Answers
  • Posted on Jun 10, 2009
SOURCE: JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Anonymous
  • 31 Answers
  • Posted on Aug 16, 2009
SOURCE: need wiring diagram for kd-shx700
Hi There, if you click on the link you'll find a wiring diagram...
http://resources.jvc.com/Resources/00/00/95/LVT1158-002A.pdf
Rich...
josetejas
josetejas
  • 300 Answers
  • Posted on Jan 19, 2010
SOURCE: Just installed jvc kd-s16 and it loses power after
Connect Yellow to Battery (always 12V), red to ignition, and black to ground. Disconnect all others. Check it. If the radio stays on and plays CD, then radio is good. You may check other wiring
How to wiring jvc kd-r690s?
To wire a JVC KD-R690S car stereo, you will need to connect the power, ground, and accessory wires to the appropriate terminals on the back of the unit.
  1. First, locate the power, ground, and accessory terminals on the back of the unit. These are usually labeled "Power," "Ground," and "ACC," respectively.
  2. Connect the positive power wire (usually red or yellow) to the "Power" terminal on the back of the unit.
  3. Connect the negative ground wire (usually black or brown) to the "Ground" terminal on the back of the unit.
  4. Connect the accessory wire (usually blue or blue/white) to the "ACC" terminal on the back of the unit.
  5. Make sure that all of the wires are securely connected to the appropriate terminals.
Keep in mind that the specific wire colors and terminal locations may vary depending on your vehicle and the specific model of the JVC KD-R690S car stereo. You may want to consult the owner's manual or a wiring diagram for your vehicle and the stereo to make sure that you are connecting the wires to the correct terminals.
If you are having difficulty wiring the JVC KD-R690S car stereo or if you have any other questions, you may want to consult a professional installer or JVC customer support for further assistance.
Why won't my JVC KD-HDR car stereo turn on?
Has it ever worked before? If not,this could be a basic install issue. To bench test, combine red and yellow and run to 12V positive and Black to 12V negative to see if it powers up.
Why does my JVC KD-DB95BT car stereo lose power?
Power lost on two units in one car is a little unique. Does it lose power in the middle of a trip or when you first get into car? I would recommend bench testing to direct 12v unit to see if car is causing voltage loss.
JVC kd-r210 flashes and won't power up?
Sub
You need to look through the JVC KD-R210 manual.
A JVC Dealer / Installer may have seen a similar problem & suggest remedy.
My jvc kd-g300 head unit shorts out and comes back on when i turn it up louder than 20-25 esspecially if the bass is turned up
Could it possibly be a loose wire behind ur deck that connects itself when bass starts to hit? Just an idea of a possibility..otherwise check all possible fuses that could be responsible for the loss of power.
KD-G421 in Vectra Envoy 99
To stop the memory loss you need to swap the red and yellow wires around. (battery power and ignition power).
To stop the date loss, you need to cut the electrical ariel/remote blue wire.
JVC KD-AVX2 new installation will not power up
your set could have damage after powering it up and connecting speakers.have the tech repair it.good luck.
2helpful
2answers
Error 10 message on display screen
Same issue but pressing Power and SEL would not reset unit. Found solution. Once again disconnected the car battery. Removed the face unit from the radio base and then reconnected the battery. Replacing the face unit AFTER the power was re-established solved the issue. (Probably pulling the radio fuse rather than toying with the battery connection would have done the same thing.)
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
