Question about Fisher and Paykel DG05 Gas Dryer
After removing some clothes to line dry, the dryer (DG05) would not restart. There was a "humming" sound, almost like the sound of a gear turning, in the control panel. I unplugged it and 2 hours later, the dryer will start.
6ya staff
SOURCE:
David Ransom
  • 23 Answers
SOURCE: Fisher&Paykel electric dryer: starts then stops
it sounds like the thermal fuse is bad. if you take the front cover off you will see a fuse with a red button. that might be what is causing it
Posted on Aug 05, 2008
doug cain
  • 7 Answers
SOURCE: my fisher paykel dryer does
after further investigation it was not just my vent tube that was clogged, it was the vent to the outside. it you are having drying problems, try to take a long screwdriver and vacuum and knock the fuzz loose and **** it up. dryer works like brand new now.
Posted on Dec 26, 2008
localwonder
Michael Masters
  • 6784 Answers
SOURCE: My dryer works however it is not drying the
HI. There are a few areas i would advise to check to resolve this issue.
The dryer uses multiple thermostats to regulate the temperature. When the temperature is higher than the preset limit of a particular thermostat, the thermostat breaks the circuit and the heater goes off. When the temperature cools enough, the thermostat closes the circuit again and the heat can come on.
Most dryers have a choice of temperature settings, therefore a separate thermostat is used for each setting. The selector switch or timer control then routes the circuit through the appropriate thermostat.
If a thermostat fails, it may prevent the heat from coming on, This happens because the thermostat does not close the circuit when the temperature falls below the operating temperature of the switch. It is a simple matter to test a thermostat; it should show continuity when the switch is cool and no continuity when it is warmer than its rated temperature.
A thermostat can also fail by being always on, no matter what the temperature. This switch would show continuity whether it was hot or cold. In this case, the heater would not shut off and the the dryer could dangerously overheat. As a safety precaution a second thermostat is used, This is called a thermal fuse. The power will be cut to the heating circuit if the maximum safe temperature is exceeded. In most cases, this is a one time fuse. The heater circuit will not function until the fuse has been replaced. Of course, it will be necessary to determine and repair the underlying cause of overheating or the fuse will just cut out again.
The thermostats are usually grouped together. The are typically oval in shape and about an inch and a half in size. They may be on the blower housing, under the lint trap or inside the vent line. There should be two wires connected to each thermostat.
Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
NOTE- Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
Posted on Oct 30, 2009
Doug Camburn
  • 122 Answers
SOURCE: Do the Fisher Paykel Dryers DGGX1 take twice the
make sure there is no lint build up inside the round housing where your lint trap goes. the holes in the housing sometimes plug up and you can't see it. one screw at the bottom and rotae slightly to remove. also make sure vent is clear
Posted on Jun 27, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: It takes my dryer an average of 4-6 hours to dry a
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Oct 20, 2010
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
I dried one load and the clothes seemed to be a little damp but try enough, when my daughter put clothes in it and pressed the button, it made a humming sound and did not want to turn, I waited a while and...
when it hums and won't start that's usually the motor,when was the last time you took the dryer apart and cleaned it?alot of people don't know that the dryer should be unplugged,taken apart and cleaned out,the vent line too,i bet if you open it up your motor is covered in lint,if the vent line is a long run you can remove it from the back of dryer and stick a leaf blower in it and blow it out to the outside,if it hasn't been done in a long time after you blow it run the dryer on air fluff and go outside and check to make sure the air is blowing out,sometimes blowing it could push all the lint up to the opening and block it,if it does you have to pull it out or get a brush and stick it into the pipe and clean the opening out,but you could have something stuck in the blower wheel if the dryer was started with clothes in it without the lint filter in it and a piece of clothing went down into the blower wheel stopping the motor from turning or the motor is bad,the dryer should be cleaned out at least once a year.
Dec 28, 2017 | Maytag Dryers
No heat in auto dry, ok in time cycle.
Sounds like the moisture sensor has gone bad...
Replace that and you will be drying in auto again...
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Apr 24, 2010 | Fisher and Paykel DG05 Gas Dryer
Dryer won't spin
hey first make sure the timer knob is set on drying cycle and not off ( know it might sound stupid but people forget sometimes) and if its making that noise the humming it means you need a new motor 100% sure its not easy to do if you have never done it before
Jun 07, 2009 | Frigidaire Dryers
Clothes dryer stops spinning before clothes are dry
sounds like a bad cycling thermostat!
May 26, 2009 | Bosch Dryers
Dryer making clicking sound, humming and vibrating hard
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up "
Apr 23, 2009 | Frigidaire GLGR331A Gas Dryer
MAYTAG MODEL MDE9706AYW NEEDS REPAIR
sounds like your motor is overheating, replace motor
Mar 01, 2008 | Dryers
Fisher and Paykel DG05 Gas Dryer Logo
85 people viewed this question
Top Fisher and Paykel Dryers Experts
Nathan Van Boven
Nathan Van Boven
Bill Eager
jimorris77
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
