Taste the water coming out of the filter ? should come from a cold water line, not the hot water line, funky smells and tastes come from your hot water heater. and I don't want to hear the hot water freezes faster bs. hot water heaters are full of stuff you don't want in your body. So if the water tastes ok....
sounds like you need to give the entire fridge a defrosting, clean it up real good. also have baking soda ready for monthly treatments, just crack a box open and stick it int the fridge or freezer.
These ice machines never did make quality ice as they just freeze still water, witch make cloudy, less than savory ice.
If you are a big ICE lover like me. a under the cabinet flowing ice machine is the best ice, as it last the longest(almost clear) and has no ill flavor.
Jay the pool pump guy longwood
SOURCE: ice maker problem
let it run its caused by stagment water in the system it will clear over time.
SOURCE: Ice tastes bad even after I changed the filter?
allow your ice maker to dispose old water that is still stucked on its hoses, just throw those unpleasant ices's and water would simply replenishes with a a fres and good supply
SOURCE: Ice tastes funny and a strange metallic or plastic type smell
Sometimes the smell comes from something in the freezer or even the refrigeratior and makes the ice taste funny. My suggestion is to clean out the freezer compartment of anything frozen that has been there a while and may have freezer burn. That may be the funny smell you are experiencing.
Hope this will help you.
SOURCE: Bad tasting water and ice from refridgerator.
i agree with rpbuice but in addition to flushing the water line you may need to replace the line then using the water dispencer run out about a gallon of water thru the door. this will clear the reservoir of bad tasting water. for the i/m throw out all of your ice then let it make a couple of batches and throw out that ice as well be sure to clean your ice bucket very good to remove any lingering tastes from the old ice.
fyi bad tasting water is generally from bad water supplies. good luck..
