Question about Kyocera Mita Office Equipment & Supplies
HOW DO I FIX KYOCERA SUM ERROR CODE F010?
My printer is flashing lights wich we now know means error code F010. What exactly is this error and how do we fix it?
kyotech
  • 25 Answers
That service code refers to the flash dimm, which is on the main pwb assy (controller). You have to try upgrading the system firmware. If the upgrade procedure fails, then you have to replace the flash dimm.
Posted on Jul 27, 2014
5 Related Answers
Anonymous
SOURCE: NAND FLASH ROM ERROR IA CODE CHECK SUM
Update Firmware on machine to latest level ,you will need the print driver and scanner driver installed
use the USB connection
Here is a link to the ftp site for firmware download
ftp://ftp.minolta-qms.com/pub/drivers/other/MC2490MF/
There is apdf that explains how to update the firmware correctly
to get started turn on machine with the menu key held down the display will change to BIOS mode
then send firmware from program downloaded
Posted on Dec 17, 2008
Anonymous
SOURCE: Kyorcera FS1030D - error light sequence
Dave,
You need to empty the excess toner reservoir in the front of the process unit.
Front as in the other end to where you put in a new toner.
All you have to do is open the side panel and empty all the toner out.
That should fix your problem.
Sorry to give you all the instructions like this but people still open up the toner end and have a lot of fun putting it back together.
Enjoy
Posted on Apr 23, 2009
Anonymous
SOURCE: kyocera mita fs1900 error code 4000:0074552
call service 2000:0045345
Posted on Jun 10, 2009
Anonymous
  • 3 Answers
SOURCE: Can you help me with kyocera fs-1030d
If a paper jam occurs while printing, the printer notifies it by the following combination of the four indicators. Remove the
jammed paper . After removal, open and close the top cover once to initialize the jam sensing
Posted on Sep 18, 2009
Anonymous
  • 201 Answers
SOURCE: Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Posted on Oct 02, 2009
What does it mean when I receive error code 1102?
To Repair (Error Code 1102 Kyocera) error you need to follow these steps:
Step 1:
Download the (Error Code 1102 Kyocera) Repair Tool
http://www.almuseo.com/download-repair?Error%20Code%201102%20Kyocera
Step 2:
Click on the "Scan Now" link
Step 3:
Then click on 'Fix'. The Fix is complete.
*File size: 1MB
Download time: <45 Secs
Aug 01, 2014 | Kyocera Office Equipment & Supplies
Code F010
Sir/Mam no such code for a EP4000/5000 Machine just checked the service manual.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 16, 2013 | Minolta EP4000/5000 CS/PRO Copier
Red light flashing
Red light flashing means there is some error in the printer. There will be some error number showing in the LCD. Let me know the code. Then I will be able to tell you the exact problem.
Mar 22, 2011 | Office Equipment & Supplies
Hi error code: Call service 6020:0053103 Can't
according to my reading, a flashing power lights indicates a problem you can solve on your own. while a error like you typed would mean something that you cannot resolve without help. a problem like a bad controller, or a bad chip. maybe a eeprom issue.
If Call service appears, turn off the printer, disconnect the power cord, and contact your service technician
Some errors cause the alarm to sound. To stop the alarm, press [Cancel].
#### represents a mechanical error (#=0, 1, 2, ...). Call for service. The printer does not operate when this message is displayed. The total number of pages printed is also indicated, e.g. 0123456.
This woiuld mean you printed 53103 pages with that printer before the error occurred.
Good Luck
articale found here
http://www.manualowl.com/m/Kyocera/FS-4000DN/Manual/166388
Feb 14, 2011 | Kyocera FS-4000DN Laser Printer
ERROR CODE "C7980". I HAVE ALREADY EMPTIED THE TONER WASTE. WHAT DOES IT MEAN AND HOW DO I FIX IT?
Hello sir; The code you display which means waste toner bottle full, just dump it .
May 12, 2009 | Copystar CS-1820 Copier
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Dec 04, 2008 | Kyocera Mita FS-1030D Laser Printer
Kyocera 3900DN Error Code
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
Sep 04, 2008 | Kyocera FS-3900DN Laser Printer
1,173 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
AAAA262430
Marvin
Marvin
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
