Question about D-Link Computers & Internet
Multicast how enable multicast
Kamal
    New Friend:
    Problem Solver:
  • 14 Answers
Please open router page and go to advanced just like in this emulator.
http://support.dlink.com/emulators/wbr2310/adv_network.htm
Posted on Jul 26, 2014
Does MA5800 support the Multicast?
Yes, it supports Layer 3 multicast networking, also supports IPv4 PIM SSM.
Protocol Independent Multicast-Source-Specific Multicast (PIM-SSM) enables a user host to rapidly join a multicast group if the user knows a multicast source address. PIM-SSM sets up a shortest path tree (SPT) from a multicast source to a multicast group, while PIM-SM uses rendezvous points (RPs) to set rendezvous point trees (RPTs). Therefore, PIM-SSM implements a more rapid join function than PIM-SM.
Different from the any-source multicast (ASM) model, the SSM model does not need to maintain an RP, construct an RPT, or register a multicast source.
The SSM model is based on PIM-SM and IGMPv3. The procedure for setting up a multicast forwarding tree on a PIM-SSM network is similar to the procedure for setting up an SPT on a PIM-SM network. The receiver's DR, which knows the multicast source address, sends Join messages directly to the source so that multicast data streams can be sent to the receiver's designated router (DR).
http://www.thunder-link.com/HUAWEI-MA5800-X7_p928.html
Jan 06, 2017 | Computers & Internet
How do I connect my router N600 to Chromecast?
  1. Check your NETGEAR router settings
  2. Uncheck Enable Wireless Isolation This step will disable AP Isolation.
  3. Uncheck Disable IGMP Proxying This step will turn Multicasting ON.
Feb 15, 2015 | NetGear WNDR3400 N600 Wireless Dual Band...
Hi, I have two VM citrix servers that i have load balanced using windows NLB. My users are on a different subnet so I have the load balancing configuration set to Multicast mode. (I have a second nic in...
I have not worked with 3Com switches only Cisco, but I thought I would post this as I found it when googling:
multicast routing-enable pim
on the vlan interfaces:
interface Vlan-interfacex
ip address ***.***.***.*** ***.***.***.***
igmp enable
pim dm
Those commands should help you get multicasting to work. notice, Vlan-interfacex means you will have to do it for each Vlan you created. Some switches do not include multicast support in their base models but make you buy additional licenses to enable it. Cisco is like that, not sure about 3Com.
Chris
Sep 08, 2011 | 3Com Switch 5500G-EI (3C17261) Network...
Can't stream media to my xbox360 or playstation3?
you might need to enable UPNP, or disable a firewall on the internal traffic. Make sure multicast is enabled, and the devices is in the same IP scope.
that all devices have ip´s like:
IP: 192.168.0.??? (where ??? is unique to each device)
Subnet 255.255.255.0 Gateway: 192.168.0.1
Apr 02, 2011 | Linksys Wireless-G WRT54G Router
How enable multicast traffic on RVS4000?
1.Your router is set up for multicast automatically
2.Look at the QOS or traffic shaping.
Apr 19, 2010 | Linksys RVS4000 Router
I am having problems with downloads with my WBR-2310 Dlink Router. The downloads are much quicker without it in line. How can I fix this? Do I need to make some type of parameter change within the router...
Yes check this settings in your Router Setup Page.
In your D-Link Setup Page.
Go to Advanced Tab > Advanced Network
Check the following :
Enable UPnP
Enable Wan Ping Respond
( Wan Port Speed - set to Automatic )
Enable Gaming Mode
Enable Multicast Speed
Save the changes.
Jan 24, 2010 | Computers & Internet
WAN requests
The feature you are referring to "Block Wan Requests" is either enabled or disabled In the pane to the right, where there are 4 subcategories to "Block Wan Requests", Block Anonymous, Filter Multicast, Filter NAT, and Filter IDENT. These 4 subcategories are your choices for blocking WAN requests. They can be either enabled, or disabled.
Nov 25, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
656 people viewed this question
Top D-Link Computers & Internet Experts
Mike
k24674
Muntejaya Ginting
Muntejaya Ginting
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
