Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
My kenmore electric ranger control panel says err.
It got very hot.
When using grill knobs get to hot to turn stoves 600 sidl
you are missing the heate plate that stops the knobs from getting hot go to ebay and put your model in and look for heate plate or some thing like that
Oct 12, 2012 | Ovens
Is the top heating element inside the oven supposed to get hot even if not set on broil?
Yes the top element does get hot even on bake but it does not get red hot just hot. It will get hot enough to burn you so be very carful.
Apr 06, 2011 | Kenmore Ovens
Hot plates go red hot even on low setting on my westinghouse avondale 529 stove
The hot plate needs a new thermostat. When thermostats go bad, there is no control of temperature and they stay on high. The circuit remains closed, not allowing any cycling of power, which regulates the temp
May 16, 2010 | Ovens
The sides and front of my oven get extremely hot, why? I am afraid to use the oven in fear it will burn the cabinets next to it. The oven is not self cleaning, is this why it is getting hot? My last oven...
Normally oven gets hot but just lukewarm externally(front and sides). Compare it when it
was still new. If it is hotter than it was, then the insulation inside have deteriorated thru time. Have it check for possible insulation replacement Hope this will solve your problem. Don't forget to vote for me. Thanks.
Sep 22, 2009 | Ovens
Cleaning the gas stove
Hello Kayerich,
Welcome,
How hot is it?
Can you keep your hand on it?
Yes to that question, the outside window can be hot.
But usually it should not be hot enough to burn you.
Just a little hot!
You said, Last time we cleaned our gas stove the window shattered. We have gotten a new window and are cleaning it again. Is the outside window supposed to get hot?
Waiting your response.
Huuum
Please remember to leave a rating
Oct 19, 2008 | Frigidaire FGB24S5A Gas Single Oven
It is an electric oven.
It doesn't have a hot surface glow ignitor????
Do you mean it doesn't have a hot surface glow indicator???
AND?Whats your question?
Sep 06, 2008 | Ovens
The hot surface light is staying on and will not go off. Is there a way to fix this?
Each element contains a sensor to detect when the element is hot, this sensor has failed. The element will have to be replaced. If there is only one light to indicate hot surface, you will have to determine which element has failed.
Jun 09, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Exterior surface of oven gets hot when turned off
What do you mean by very hot? Is it too hot to touch? Hot enough to sizzle when a drop of water is put on it?
Oct 06, 2007 | Dacor MCS130 Millennia Electric Single...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
109 people viewed this question
Top Frigidaire Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
