Question about Toshiba 62HM95 62" HDTV
Toshiba #62HM95
Behind my projector is a annoying sound. At 1st I thought it was the cooling fan.. The noise comes from the bulb that is being kept cool by the fan. The noise is more like a humming sound. When the projector is turned on after bout a min. or so this humming noise begins to kick in. When it is turned off Still! this humming sound wont stop till the projector is unplugged. I appreciate if anyone could give some type of solution.
THANK YOU!!!!!
Posted by lsg075 on
  • jwise170 Oct 11, 2008
    My color wheel is making a humming noise. I pulled the back panel off and can feel where the noise is coming from and it is not the cooling fan.
Anonymous
    Genius:
  • 1,139 Answers
I am wondering if this sound might be your color wheel spinning. The color wheel often makes a low humming noise as it spins. Try checking to see if this is not the source of your noise. You need the color wheel to generate the colors needed to turn the B&W picture generated by the DLP into a color picture.
Thank you,
Shuttle83
Posted on Dec 21, 2007
Anonymous
    New Friend:
  • 4 Answers
Yes, the problem is the color wheel. Those are not sold by toshiba alone. You have to buy the light engine from them (a lot of $$$)
I found color wheel for sale on eBay. Just type "toshiba color wheel and you will see them there. They are little wider then the original buy fit perfect and seem to last much longer too.
Posted on Jun 16, 2010
  • Anonymous Jun 16, 2010
    The color wheels are abailable on eBay. They are not original but are new and 100% compatable. Also, cost much less then a light engine:)
Anonymous
In these toshiba dlps.. you can only purchase the light engine that has the color wheel attached as well as other components its only sold that way as one unit.. it stinks and its expensive.. mine make a loud cooling type noise when it is off the same as whe it is on .. and now lines are starting to appear ont he side of my screen.. im goin for the light engine.. replace it all
Posted on Feb 19, 2009
Anonymous
I am having the same problem. I am getting a screaching noise (bad bearings) coming from some spinning part in the TV. I too took the back of, used pressured air to blow out any dust off the fan closes to the light...but it seems to be fin and is not the source of the noice. I have a feeling it is the color wheel but I am unsure on how to determine this. I will try changing the color to B&W to see if this will help identify the problem. Is it possible to only replace the color wheel if this is the problem or do I have to replace the entire light engine?
Posted on Oct 17, 2008
When TV on we hear aloud noise and it will continue for several minutes after the TV is turned off. Any help, thanks
sounds like a fan issue which continues to run to cool down the set after you turn it off. Squealing is usually the sound which is heard and it can also be a roaring sound depending on how bad the fans bearing is.
Jul 19, 2011 | Toshiba 62HM95 62" HDTV
It makes a wierd noise
The bulb housing has come loose...
When the bulb heats up & cools in normal use, the housing will contract and become loose.
Unplug and re-seat the bulb and housing ...
Another possibility: If the replaced bulb shattered in the projector, there may be debris in the fan... use compressed air ($8/can RadioShack) to clean out (make sure the projector / bulb are cool before using compressed air.
Hope this helps!
Sep 09, 2009 | InFocus ScreenPlay 4805 Multimedia...
My projector makes a really annoying noise
It is also possible that the bearing is going bad on the fan. I'd look into getting a replacement fan if that's the case. It is probably cheaper than a replacement bulb that would be needed if the fan failed entirely.
Jul 09, 2009 | Toshiba TDP-P5 DLP Projector
Humming noise
The light enigine shouldn't be that difficult to replace if you have a decent amount of time and are moderately mechanically inclined. You can order the original Toshiba replacement light engine for this model (62HM95) from a major Toshiba parts distributor at the link below:
Toshiba 62HM95 Replacement Part Light Engine / Optical Block
Apr 01, 2009 | Toshiba 62HM95 62" HDTV
Simutaneous clanking and dimming
Hello Miggs,
This sounds like a color wheel or cooling fan issue. I would take the set back and have them check the color wheel and fan assemblies.
I hope this helps
Thank you,
Shuttle83
Jan 11, 2008 | Toshiba 62HM95 62" HDTV
Annoying projector noise
Well here is a partial solution. Turn off Dynamic Iris and the noise will go away. Now could someone tell me how to fix the Dynamic Iris?
Dec 06, 2007 | Panasonic PT-AE900U Multimedia Projector
Toshiba 62HM95 62" HDTV Logo
1,182 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
