Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I need a Table Top Mount for my 52" Sony Bravia, Model year 2007 KDL-52BR3
2 Related Answers
Will Laxton
  • 25 Answers
SOURCE: Sony Bravia KDL series 52"
Check the fuses on the power board. there is one fuse on primary side and one on secondary side.
Take of back panel and follow plug into the tv.where it ends is the power board.always use caution.the capacitors in there hold high voltage even after unplugged for a couple of days.Discharge capacitors before servicing the board.
Posted on Jun 28, 2011
SD Tech
SD Tech
  • 14553 Answers
SOURCE: Looking for a table top mount for my Sony Bravia 40" TV (KDL 40V3000). It's no longer available from the manufacterer. Is there a universal mount that will fit?
I would check with MCM electronics who sells nearly 100 different universal mounts for many sets. They have a online catalog.
Posted on Dec 02, 2012
Install table top stand
If you wish to get more details about this, check the site linked here. It has disassemble instructions with illustration. You can understand the procedure you wish to know. Pull up older posts.
Nov 25, 2013 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Dec 02, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
How do i remove the table top stand from my sony bravio model KDL-52V4100
Need replacement screws for my sony 52v4100..I lost the screws for the table top
Jan 28, 2012 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
I have a sony 52 inch bravia kdl-3000 and there is a line on the left side from top to bottom. if its the panel that needs to be replaced what would it cost.
Sony panels run around $1,500.00 and up. Go to Face Book and type in (I Have a Defective SONY TV.) Click on LIke So you can Post Your Problem. Their you can get a replacement TV From SONY !!!! If it turns out that you do have a Bad Display Panel.
Oct 18, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
We need our Sony 52W4100 Bravia screen replaced. What is the cost?
Sony BRAVIA KDL-52W4100 52 in. HDTV LCD TV
Part # 1-802-791-12, cost approx $2,251.54 + core
Parts reference: Andrews electronics, 800 289 0300.
May 01, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
How to remove the table top stand for wall mounting?
Take all the screws out of the base,might require an Alan wrench.Take mellet make a couple taps.Should pull the base right out.
Feb 07, 2010 | Sony KDL-32S3000 32 in. LCD Television
Lost the table top stand for my KDL-40s4100
I might have one of this table top stand.
Write to [email protected] for more info.
Jul 08, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony Bravia KDL-32s2000 down from wall mount and can't find stand
Yes, Sony Parts has them available:
800-488-7669
The stand is $107.59, and requires four screws to attach to the TV. They're $2.25. (quite the bargain!)
The model number of the stand is X21033652.
Please rate my answer if it solved your problem.
Apr 19, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
51 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
