Question about KitchenAid Professional 600 6 Qt. Stand Mixer -Cayenne Red
I need the Manual Kitchenaid 600 mixer
Manual
Ross Keen
  • KitchenAid Master
  • 1,365 Answers
Tip it upside down and read the proper model number then enter it into the box on this page at the Kitchen Aid web site
http://www.kitchenaid.com/customer-service/manuals/
Posted on Jul 26, 2014
I need to replace the Beveled Gear for my Pro 600 mixer. it seemed an easy task. However, I am stuck in removing the Beveled gear. I cannot remove it after removing the retaining ring. help pls.
If you have the gear cases apart and the bevel gear exposed then you just push the planetary shaft up through the middle of the bevel gear. You will see that the shaft is driven by the gear via a loose fitting pin through the shaft. Pull the pin out (with fingers) and then the bevel gear will lift up off the shaft without the need to fully remove the shaft. Note the fibre spacer/thrust washer under the bevel gear between the bottom case and gear, don't lose it.
Aug 08, 2016 | KitchenAid Professional 600 6 Qt. Stand...
How can I fix the crank so it will raise the bowl?
You need to replace the plastic lift lever on the crank shaft hidden under the motor housing up inside the pedestal. Put it upside down on a towel and undo the 4 large philips head screws holding the pedestal to the bottom of the motor housing.
Jul 30, 2014 | KitchenAid Professional 600 6 Qt. Stand...
Wont start
If it will not turn on when cold then you are likely looking at a new motor. If there is a resettable fuse reset it.
Jan 25, 2014 | KitchenAid Professional 600 6 Qt. Stand...
Kitchenaid mixing shaft falls out w/ use
If it is model 5KPM5 then there is a pin through the shaft inside the planetary that engages the pinion gear. There is a circlip above the gear clipped to the shaft that holds the gear into engagement with the pin. I've not seen one drop the shaft out in my life, the circlip would need to pop off & the gear would need to jump up and then the pin would need to slide out. All the bits would be there inside the planetary waiting for you to discover them.
Nov 16, 2012 | KitchenAid Professional 600 6 Qt. Stand...
Ticking sound in kitcheaid mixer
Remove the planetary and see if the noise vanishes, if not then you will need to open up the gearbox. It could be the pin retaining the fuse gear or maybe even the fuse gear itself failing. It seems unlikely though as you were only whipping cream and there is no effort in that.
Sep 03, 2012 | KitchenAid Professional 600 6 Qt. Stand...
OILING/GREASING INFO.FOR OLDER KIT. AID BLENDER/MIXER
Would need your model number to look for a service manual, but first search did not show ANY service manuals online for a Kitchenaid blender. You can call the manufacturer at this number
Contact Kitchenaid Customer Experience Center at 1-800-422-1230. they may be able to help you find a local service center near you.
If you want to send us the model number of your blender we can look again for a service repair manual. Thank you for using Fixya.
Dec 28, 2010 | KitchenAid Blenders
Oil Leak-Stand mixer
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Jun 18, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Will kitchen aid purchased in USA work in australia?
The Australian outlets will zap that blender - you need to purchase a 240V to 120V transformer in order to make it work.
Mar 30, 2009 | KitchenAid KSB560WH 5-Speed Blender
Beaters
KitchenAid Turbo Beaters - Stainless Steel
Model: KHM2B
$14.99
Features:
Replacement or Extra Set of Self-Cleaning Stainless
Steel Beaters Mix Cookie Dough Easily.
Turbobeaters fit only Hand Mixers manufactured since
September 1997.
If you have a model produced before 1997 please call
the KitchenAid Customer Satisfaction Center at
1-800-541-6390 with the model and serial number from
your hand mixer for further assistance.
Mar 23, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
KitchenAid Professional 600 6 Qt. Stand Mixer -Cayenne Red Logo
97 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
Lawrence Oravetz
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
