Question about Eddie Bauer Musical Rocking Bassinet 10330WOW Crib
How do I take off the bedding for washing
I've taken off one end of the bassinet, however I cannot undo the end where the batteries are inserted.
3 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 13 Answers
SOURCE: where can i find the bedding for the eddie bauer
Most baby stores (Babies R Us, BuyBuy Baby, Toys R Us, etc) carry bassinet sheets. They have elastic edges so they fit most sizes. I found that for my granddaughters abssinet, there were few color choices so I used pillowcases and tucked the excess under the mattress. Other than that, if you want something made specifically for your brand, generally you'll need to contact the manufacturer or make it yourself.
Posted on Apr 21, 2010
Kandi Cook
  • 823 Answers
SOURCE: dont know how to remove
Which part of the bedding is soiled and needs to be washed?
There should be a flat sheet that covers the mattress pad, an optional top sheet, a comforter, a dust ruffle, pillow sham and a decorative cover for the hooded area.
Remove the comforter & top sheet & set them aside. Pick up the mattress inside the bassinet, remove the flat sheet on it and put that with the other items to wash. Leave the mattress pad out, and you should be able to see the dust ruffle. The dust ruffle goes under the mattress pad and hangs like a skirt on the bottom of the bassinet. Pick up the dust ruffle and untie any ribbons that might be used to anchor it on the sides or bottom area. Depending on the bedding set you bought or are using with the bassinett, the piece that goes around the hood area might have elastic to keep it snug, or if you are using the default that came the model that is sold in California, US - its not really removeable without a lot of trouble and other problems - (I would suggest leaving it on unless its REALLY soiled).
Posted on Jul 08, 2011
I need instructions for taking apart a Simmons baby bed. Cannot locate model number. Bed purchased in 1985.
sorry but without seeing it , I would only guess to remove any bolt /screws you see.
Jun 24, 2016 | Baby Gear
Dont know how to remove the bedding from the bassinet to wash
Jun 07, 2011 | Eddie Bauer Musical Rocking Bassinet...
How do I disconnect the fabric from the bassinet hood so that I can wash it?
the piviot of the hood should be connected with a screw or bolt undo this on 1 side only
Jul 14, 2009 | Graco Bedside Bassinet 5840 Crib
Unique Oak Treasures Crib - Full Bed Bassett Model 5542-0521
We have this crib as well. We bought it from Babys R' Us in 2005.
We also purchased the rails to convert it to a full sized bed. It did not come with instructions but I can explain to you how to put it together.
The rail conversion set should come with 2 pieces of wood that act as the bed frame. You do not need to purchase the extended frame. The set should also come with 4 long screws, the hex tool to tighten it and 4 metal pieces. You might also have some wood nail cover plugs.
Once you've taken apart your crib, the only pieces that you will need are the 2 longer pieces of the crib...the headboard and the footboard. The 2 shorter side pieces which served as a headboard and footboard as a crib and the metal grate to hold up the mattress can be put into storage.
On the sides of each of the new wood rails, you will see a circle indent on each end with a hole. You will insert one of the long screws into each and then insert it into the head board. You must use the special tool to screw/ tighten it in. The metal flat pieces can be inserted into it the circle befor eyou are done tightning so that it does not strip or damage the end of the circle. You do this with the other rail on the other end and then add the footboard using the same process. If you would like, I can send you a copy of what this looks like close up. ( the cricle indent with screws. The bed is extremely strong. We've all napt in it as a family along with our 2 large dogs. I highly recommend ordering the extra long/ tall bed rails from OneStepAhead for security because my son has rolled out of the bed and it is super tall!
http://www.onestepahead.com/catalog/product.jsp?productId=534602&parentCategoryId=85183&categoryId=85216&subCategoryId=86203
Jul 12, 2009 | Bassett Cottage 3-in-1 Crib
Getting the canopy off to wash it
Remove/losen the velcro for the bottom of the bed . There are three screws on each side of the base were the music box and volume is. You want to remove the MIDDLE screw ONLY on each side. On each opposite end of the base is a large screw and on the other side is a smaller screw, unloosen the screws and the base of the bed fall off so that you can remove the lining. Remember you only need to remove the middle screw.
Jun 25, 2008 | Eddie Bauer Musical Rocking Bassinet...
Bedding
I got this bassinet 2nd hand. I can tell you that I did wash the whole set. You have to take the screws out at either end to remove the cover (one screw is behind the batteries in the music box). I removed the plastic parts (the slits are closed with velcro for the flat plastic panels so the plastic simply slides out). The hoops were a little more difficult but since it is an overlap closing and the hoops are flexible, you can remove them. Simply wash in cold water and hang to dry. When its dry, you can put the plastic slides and hoops back in the same way you took them out. Came out fine.
Jun 19, 2008 | Eddie Bauer Musical Rocking Bassinet...
Washing the bedding
no. wash the canopy manually.. soak it in soap and water then rinse.
Jun 18, 2008 | Eddie Bauer Musical Rocking Bassinet...
Changing from a crib to a toddler bed
1-Lower drop side to lower position. Then on the opposite side of the crib, remove stationary side. To remove stationary side, press the small tab on the end hardware(brown plastic piece that connects the rail to the frame) and then pull rail up.
2-Before reinstalling the conversion safety rail(csr), remove the mattress support bolt that is on the side the the csr opening will be(the foot of the bed). A new bolt will be used to reattach the mattress support in the next step.
3-Slide csr hardware onto the hardware on the crib ends. Insert two 1/4-20x2" bolts into each end. One bolt will replace the mattress support removed in step 2. Be sure to put the bolt back through the mattress support bracket before screwing into the end.
I have the instruction page with pictures if you would like a copy emailed.
[email protected]
Sep 15, 2007 | Childesigns Carrollton Crib
Eddie Bauer Musical Rocking Bassinet 10330WOW Crib Logo
181 people viewed this question
Top Eddie Bauer Baby Gear Experts
superdad1976
Nikki  Mclean
Nikki Mclean
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
