The easiest way for most people to update iOS 10 to iPhone is over the air, directly on their device. It's fast, efficient and simple to do.
1.Click Settings, then tap on General
2.Tap on Software Update.
3.Tap on Download and Install.
4.Enter your Passcode, if prompted.
5.Tap Agree to the Terms and Conditions. Tap Agree again to confirm.
6.Tap Install Now to begin the update. http://www.leawo.org/tutorial/how-to-update-ios-9-2-to-iphone.html
Hi there joe i want you first of all to check your internet connection if it is connected please check the storage or if the playstore is restricted in your country if not try uninstalling then re installing or just try the app if you didn't install it yet or do contact thier support center i hope this answer was helpful
I suggest that you troubleshoot first, instead of a hard reset. Factory reset is within settings.
If any google app won't download nor install, it's probably because your google services are not updated or is corrupted. Try the next steps before factory reset.
1. Go to settings, scroll down to app.
2. From here search for PlayStore and tap it.
3. Tap Clear Cache and Clear data.
4. Go Back.
5. Search now for Google services, this one is not under the download tab, which you can notice at the top of the screen, instead got to All and scroll down until you find it.
6. Tap Clear Cache and Clear data if available.
7. Reboot phone or tablet.
Most of the time this procedure do work, some people also opt to remove the google account and sign in after the reboot.
After the boot, open the PlayStore, accept the agreement and try to download anything from the PlayStore that is compatible with your tablet. Also, just to be sure, go to settings, security, look for Unknown Sources and enable it. This feature allow you to install any apk file that is not from the PlayStore.
Make sure you have a wifi connection. Playstore is on the internet so you have to be able to access the internet.
Also, if the Playstore app that came installed on the tablet is lost or needs re-installed for some reason, then you won't be able to re-install it on your tablet unless you also have gmail running on the tablet or google+ or some other app that Google can use to identify you as the tablet owner.
You must be using Android, if that is the case, then just open PlayStore, then tap at the top left to open another windows and choose Apps or My Apps, here is a list of all of your apps. One tab is for installed apps, the other on is for all apps, installed or not. You can tap the search icon at the top and write the apps game that you want to recover, tap install.
If you have an iPad, or any Apple device, open AppStore, look for the Purchase section, search by scrolling down for the game that you want to recover, just tap Get and it will re-install.
Best of luck.
Make sure by going to the Application Manager under Settings and verify that you haven't just lost the icon on some page. The playstore is normally loaded as part of the operating system for your device. There are places where you can download an installable file for the playstore, but some devices will not allow installation of downloaded .apk files, or require you to turn off a setting that prohibits installing downloaded files. Without knowing the mfr and model number of your device, who knows what you would have to do to get this app reinstalled if you truly have somehow deleted it. Google Play Store 5 0 38 APK Download APKMirror
First make sure you have a good internet connection, WiFi or Ethernet. Access play from your application list. If on do not have it download from Google.com. When in Play select what you want to download and select, install, you should then be asked if you agree to access of your tablet, agree. It will then download the app and it will apper in your apps list after a short time.
