Dishwasher about 11 years old, just started making a noise similar to popcorn kernals loose and banging around inside
SOURCE: Dishwasher Making Loud High Pitched Noise.
debris caught iside pump assy is what it sounds like
SOURCE: kenmore elite dishwasher noise
I had the same problem where rubber gasket that seals the motor bearings leaked water into the bearing and rusted out the bearing.
I scrapped the motor into every little pieces and extracted the bearing and just replace it. Now it is quiet as a mouse.
You need a bearing puller to get the bearing out for about $20 and the bearing is $6.
During the repair i slightly bent the shaft and i didn't straightened it properly so it wobbles a bit. But it works and if really quiet.
SOURCE: Kitchenaid dishwasher making funny noises while running
HI. this sounds like a busted impeller in the pump housing. there are two impellers. one for the wash and one for the drain. the drive shaft will strip the impeller center nut, causing this noise. I would inspect the pump housing for lose impeller action. replace the faulty impeller if found to be damaged.
SOURCE: dishwasher leaking around the bottom of the door
I had the same problem in 2004, lots of Bosch trained repair techs, calls to Bosch, and the appliance dealer we purchased it from with no answers. Our kitchen cabinet bases were ruined by the flooding that occured. After months of trying to get help I insisted on speaking to a supervisor that told me it was my fault for putting a flexible cutting board on the right side a blocking the vent. I told her that no where in the manual did it mention this issue and none of their trained techs were aware of this flaw in their design. When I asked about getting my cabinets repaired she said that was not an option. When I mentioned possible legal action her response was "good luck with that". Here it is 2009 and they recently called about a possible fire hazard recall for the control panel. The Bosch trained tech that came out to complete the repair knew nothing about the vent/flooding issue.
SOURCE: Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
