Question about Konica Minolta bizhub Office Equipment & Supplies
How to reset error c3101 konica c352 - bizhub Konica Minolta Office Equipment & Supplies
Adorjani Laszlo
  • Konica Minolta Master
  • 1,316 Answers
C 3101 Fusing roller separation failure.Check the fusing retraction motor and clean the fusing roller retraction sensor PS 38
Posted on Jul 26, 2014
3 Related Answers
Anonymous
  • 4 Answers
SOURCE: Konica Minolta Bizhub C352 error C-B116
try with trouble reset
turn off the machine, press and keep pressed utility counter, turn on the machine
on the display you'll see the Trouble reset button on the display, touch it and turn off and on the machine
check if error disappear
Posted on Oct 19, 2008
Anonymous
SOURCE: Konica Minolta Bizhub C352 error code C-0204
I had the same recently.
Problem is caused by a paper which stuck behind the paper tray. It happens when You put to much paper od while moving (for example). Solution: take out the paper tray 1 and 2, remove the paper from the space behind the trays.
Pixel
www.mojito-networks.com
Posted on Jun 23, 2009
fordexpert
  • 5692 Answers
SOURCE: Please what is the administrator password for
You are listed in the Cars and Trucks section of Fixya. You will need to list in a section more closely matching your product to get help from those Experts.
In general some Electronics will accommodate using the Enter key when the cursor is populated in the Password box. This basically sets the Password to the Enter key as the Password action needed to gain access.
Additionally, some makers have good online directions when you enter the makers Website and pick the Product number you own as a Search term within the site. Online manuals are often available or you can get Phone numbers to contact the maker.
This is probably as much help as you may get from Experts in the Cars and Trucks section.
Posted on Sep 04, 2013
I have a proplem in konica minolta bizhub c352 how to sort the problem i have an error code 3451
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day. ENSURE YOU WAIT THE 10 SECONDS
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 15, 2016 | Konica Minolta bizhub Office Equipment &...
Bizhub c352 error 3451
Error code c3101
What brand and model printer do you have? On some Konica-Minolta BizHub printers, the C3101 error indicates that the fuser roller isn't working properly. The roller isn't moving to the retracted position or the pressure position in a timely fashion. The teeth for the gears may be damaged or the sensor isn't working correctly. You'll need to remove the fuser and check if it needs to be replaced due to damage to the roller assembly. Also check the M12 wiring connector and the PS38 I/O sensor. Check the M12 operator. The M12 may need to be changed. If those fail to fix the problem, then the PRCB may be bad and need to be replaced.
I hope this helps.
Mar 13, 2015 | Office Equipment & Supplies
Bizhub c352 error message c3101
Replace the fusing unit
May 20, 2014 | Konica Minolta bizhub C351 All-In-One...
Reset image unit (Magenta) Konica Minolta Bizhub C352
Change the chip or enter in service mode and change the imaging unit life duration to long life.The copier displayed continuosly Please change the image unit,press OK and ignore.
Feb 13, 2013 | Konica Minolta bizhub Office Equipment &...
C3452 error code bizhub c352
Sir/ Mam,
If after this procedure the code comes back do not reset again, get a tech out and expect to pay for a new fuser unit, continue resetting can cause the fuser the hot part to catch on fire ruining a perfectly good day.
1. Turn OFF the Main Power Switch (Located in side front cover). (ensure Control panel power switch is on)
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
Jan 10, 2012 | Konica Minolta Office Equipment & Supplies
Oct 19, 2008 | Konica Minolta bizhub C250 All-In-One...
569 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
