Resetting the password on a Sharp 14V-W150M projector can be a bit tricky, as the process may vary depending on the specific model and software version. Here are a few steps you can try to reset the password:
Check the manual: The first step is to check the manual that came with the projector. It may have instructions on how to reset the password.
Use the default password: Some Sharp projectors have a default password that can be used to reset the password. The default password is often "admin" or "password". If you're unable to find the default password in the manual, you can try searching the internet for it.
Contact Sharp support: If you're unable to reset the password using the steps above, you may need to contact Sharp support for assistance. They may be able to provide you with a reset code or assist you with the process.
Factory reset: If all else fails, you may need to perform a factory reset on the projector. This will erase all settings and restore the projector to its original factory settings, including the password. The factory reset process may vary depending on the projector model, so it's best to consult the manual or contact Sharp support for specific instructions.
It's important to note that a factory reset will erase all settings and restore the projector to its original factory settings, including the password, so it's best to have a backup of all important settings. It's also important to note that attempting to reset the password can be tricky and if you're not comfortable with this task, it's best to consult a professional technician or Sharp support for assistance.if i was able to help my cashapp $ralphpapi thank you have a blessing day
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. https://homenol.blogspot.com/ https://remotesearch.blogspot.com/ https://electronicshelponline.blogspot.com/ https://electrohelponline.blogspot.com/ Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device./
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience. Unlock procedure to many popular brand TVs are given. http://electronicshelponline.blogspot.com/
Check the input voltage to IC. If it is absent, the IC won't work. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
