SOURCE: Canon iP1800 printer,flashing orange light under the green 'on'
First off, How many times does it flash organge before it goes to green?
two: out of paper
three: paper jam
four: Ink has run out
Five: FINE cartridge cannot be found
Seven: FINE Cart. not installed in correct position
Eight: Ink absorber almost full
Count how many times it flashes. Then get back to me
SOURCE: when i turn my printer on the light flashes green
Here are all the flashing explanations:
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
SOURCE: flashing 3 times orange then green?
4 step to Reset waste counter CANON PIXMA iP 1500
STEP 1:- Disconnect printer from AC power(unplug it from all source of power supply leave it for 5min then back after))
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
SOURCE: canon i250 flashing orange / green light
turn the printer off by the socket. hold down the on button and keep held down whilst turning on the socket switch. Then press the button next to the on (i don't know what it is called) , so it goes onto orange then again to get to green. now it should stay on green and print. i hope this i useful
SOURCE: my printer flash green then oranfe and again and
5 times says the feed roller is not turning properly, sometimes the gears break and other times something falls in the back and stops the roller from turning. It's a different error if the orange flashes 5 times, or if it flashes orange and green 5 times.
