Question about Frigidaire GLTF2940ES Front Load Washer
Loc error code Frigidaire frontloader - Frigidaire GLTF2940ES Front Load Washer
Gruesome Werewolf
    New Friend:
  • 21 Answers
From the frigidaire site.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Posted on Jul 24, 2014
2 Related Answers
Anonymous
SOURCE: I can't get the LOC
push options and select button at the same time to unlock
Posted on Jan 25, 2009
57 varieties
Karl Wright
  • 1653 Answers
SOURCE: I have a gas Frigidaire Gallery dryer. There is
This indicates there is an error with the door lock mechanism. It will most likely need to be replaced. This will prevent the dryer from working and is a safety feature to prevent injury while the dryer is in operation. It is fairly quick and cheap to repair.
Posted on Nov 13, 2009
Front loader. Why does it run for about 30 seconds, then stops, beeps, and displays code e64?
Good Morning friend, thank you for your post!
I see that your Frigidaire frontload washer runs for 30 seconds, then stops, and produces an error code "E64". It appears that might be an invalid error code. I would recommend performing a reset on your washer and you can do that by unplugging the power cord for at least ten minutes. If you continue to receive the error code or a new error code please reply back. I would like to assist you further. -Matt
Jun 04, 2015 | Frigidaire Washing Machines
Loc error code on Frigidaire frontloader
To avoid having someone accidentally start or stop the washer, press OPTIONS and Select at the same time and hold for about 10 seconds until the Control Lock) lights up. "LOC" will be displayed alternately with the estimated cycle time. Turning the Cycle Selector knob or pressing any button will produce flashing indicator lights and/or beeping. To unlock the controls, press and hold OPTIONS and Select for about 10 seconds. Frigidaire GLTF2940ES3 Quick Start Manual Page 3
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
Error code loc
please read this over your error codes are invalid.
Jan 23, 2014 | Frigidaire Affinity FAQE7011KW Electric...
My frigidaire GLTF2940ES0 displays LOC when i press start
Hello & Welcome to FixYa
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 02, 2011 | Frigidaire GLTF2940ES Front Load Washer
Error code LOC on frigidaire front load dryer
hold down "OPTION and "SELECT" button at simaltaniously until screen resets. This should work for you.
Jan 01, 2009 | Dryers
Frigidaire - GLTF2940FS0 -LOC message on display
Peace,
ngafm at your service,
With an error code or loc message the only way to find and to repair this is,
First unplug the washer and wait a ten minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Sep 08, 2008 | Frigidaire Affinity ATF7000E Front Load...
Error code "loc" on GLTF2940ES0 washer
turn the selector knob so the machine comes on then press the "options" and "select" bottons at the same time for 3 seconds.
Oct 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
346 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
