Heating & Cooling Logo
Question about Frigidaire Heating & Cooling
Where is the button to reset on a frigidaire air conditioner
Where is the reset button?
Frigidaire
  • Official Brand Answer
  • 2,267 Answers
Hi friend, that's a great question!
To reset your Frigidaire air conditioner you would need to make sure the appliance is turned off and unplugged. On the power cord you will see a test button, push that button and you will hear a click. You would then press the reset button you will hear a click again signifying that the appliance has been reset. Then plug your air conditioner back in and it should be reset. -Matt
Posted on Jul 28, 2014
5 Related Answers
Anonymous
  • 113 Answers
SOURCE: air conditioner unit will not come on ,no reset button
some have a reset on the plug
Posted on Apr 27, 2009
Paul James
  • 95 Answers
SOURCE: Thru-the-wall air conditioner won't turn on
Check for power at the plug in, if it's got power take it back under warranty.
Posted on Jun 10, 2008
Anonymous
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
Anonymous
SOURCE: Electronic control on Frigidaire air conditioner not working
which one take live or nuetral ?
common
start
run
thanks
Posted on Jul 11, 2009
Dan Favata
  • 233 Answers
SOURCE: I have a frigidaire window air conditioner
I assume that you are speaking of the high pressure cut-out switch, (usually has a red button) if that is the switch then you need to remove the unit from the window, take it to the car wash and clean the condenser coil. If you are speaking about the GFCI located in the cord, it could be the cord itself or you have a componenet shorted to ground tha needs repair
Posted on Jul 12, 2009
2answers
What does H1 code indicate?
Hello E, I appreciate your post!
I see that your Frigidaire air conditioner is displaying an error code of "H1". I have reviewed the air conditioner and the "H1" error code could be an "HI". The "HI" error code means that the room temperature is above the display range. I would recommend performing a reset on your air conditioner. In order to reset the air conditioner you need to unplug the power cord you can press the reset button and then the test button that should restart your air conditioner. If that does correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful for you. -Matt
1helpful
Model FAZ12HS2A. When in Heat mode, why does it blow cool air?
Hello J, thanks for your post!
I see that your Frigidaire air conditioner is not emitting the proper air when in heat mode. I would recommend performing a reset on your air conditioner and you can do that by disconnecting the power cord. Once you have removed the power cord, press the reset button and then the test button. You should then be able to plug it back into the wall and start it up. If you continue to have issue with it an electrical component may need to be replaced and I would recommend this be completed by a professional technician. They would have the knowledge on how to properly disassemble the air conditioner without any harm. Good luck! -Matt
My fan speeds on my frigidaire window unit keep changing by itself. Input and advice please!!!
Hello Jordan, thank you for your inquiry!
From my understanding the fan speeds on your Frigidaire air conditioner changes on its own. Do you own a remote with your air conditioner? It could be getting accidentally pressed and that is causing your fan to switch. If you do not have a remote with your air conditioner it could be a potential issue within your control panel or keypad. I would then recommend performing a reset on your air conditioner and you can do that by unplugging the power cord and pressing the reset button. Once the reset button has been pressed you would need to hit the test button and then you should be able to plug it back in. If this does not resolve your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
My Frigidaire AC unit doesn't want to turn onafter plugging it in
Thank you for your inquiry, Eddie!
From the information you have provided your Frigidaire air conditioner is not turning on after you have plugged it in. I have identified a few possibilities of what could be causing the problem with your air conditioner to be the control panel or power cord. You may be able to perform a reset on your air conditioner by unplugging the power cord and pressing the reset button. You should hear a click and then press the test button. Once you plug it in it should start. If your air conditioner does not start I would suggest contacting the manufacturer for any additional assistance. Hopefully this information is helpful. -Matt
Why does it starts up then shuts off and all the lights start blinking
Hey friend, I appreciate your post!
I see that your Frigidaire air conditioner will start up then shut off and blink. It could possibly an issue with control panel or the power source of the appliance. I would attempt to perform a reset on the air conditioner which would be removing the plug and pressing the "Test" button, you will hear a click and the button will pop out. Then press the "Reset" button, you will hear another click then plug the appliance in. Those are the steps to resetting your air conditioner, if that does not successfully correct the problem please reply back. I look forward to your response. -Matt
Ac unit keeps tripping the reset button
Good Afternoon Friend,
I understand your Frigidaire air conditioner, model# LRA074AT7, which keeps tripping the reset button. I see that it will start up and then trips the reset button after a minute or two. First, be sure the electrical service is adequate for the model you have chosen. This information can be found on the serial plate, which is located on the side of the cabinet and behind the grille. Secondly, be sure the air conditioner is properly grounded. To minimize shock and fire hazards, proper grounding is important. The power cord is equipped with a three-prong grounding plug for protection against shock hazards. Lastly, your air conditioner must be used in a properly grounded wall receptacle. If the wall receptacle you intend to use is not adequately grounded or protected by a time delay fuse or circuit breaker, have a qualified electrician install the proper receptacle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
1helpful
When i plug in my frigidaire fac125p1a the reset button trips immediately. won't turn on.
compressor has gone to ground. In other words the reason the reset button trips is to prevent any electrical shock due to the compressor going bad. Only way to fix this is to have the compressor replaced
Top Frigidaire Heating & Cooling Experts
David Shaub
Jaime Hernandez
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
