IS MY WATCH GENUINE
SOURCE: Tag Heuer Ladies Professoinal 2000
Hi Dude, it's one of those things your going to cuss once you know. Just unscrew the Bezel.Thats it. Steve
SOURCE: Change the date on my TAG Watch
if it has hands the winder will be screwed in undo this anti clockwise then click it out once for date twice for time, if this helps please rate me joe
SOURCE: I can't seem to set the time on my used tag heuer watch
Probably your watch has a screwdown crown and prior to attempt any
settings you have to unscrew it. Some peoples fingers are stronger then
others, so, try that with a pair of plyers. Cover your crown with a
soft cloth and then grip with plyers(this will avoid any damage).
Thread is right handed and unscrewing is done by turning the crown
anticlockwise.
After setting the time don't forget to screw the crown back- it is for water resistance.
If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
PS
If the watch is rusty, you can brake the crown off while trying to
unscrew it. Don't panic yet, as in this case you will need a watchmaker
anyway.
Don't forget to rate, please.
SOURCE: Tag Heuer watch runs fine; can't set time or date.
Are you aware that the crown is threaded and it needs to be unscrewed and pulled out once to adjust time and twice to adjust date
SOURCE: I have a Tag Heuer Monaco watch. I has 2
The small seconds hand do not stop because it has nothing to do with chronometer. It is ordinary seconds counter and will move independent of chronometer.Click on my profile (escapement), then click on Tips and Tricks. There you will find link to Tag Heuer watch manuals. It might lelp you. Rate me, please
Testimonial: "very helpful. quick results. thanks"
