Question about NEC Dterm DTP 16D-1 Corded Phone
How to divert calls - NEC Dterm DTP 16D-1 Corded Phone
SC Spike
    New Friend:
  • 91 Answers
You can forward all to another extension or to an outside number. You can also forward busy/no answer to both of those, but then it'll cancel your busy/no answer to voicemail. Speaker 41 plus ext or 9 plus outside number will set CF ALL, speaker 43 will set CFBNA, 42 and 44 to cancel. These are the default codes for NEC pro II, Elite, and IPK. The DTP phone also works on other systems that have different codes.
Posted on Oct 06, 2014
I have BT line and have call divert but can't remember how to divert calls, HELP please
Check which services are active [System X] *#001#
Charge advice (before call) *40* (Number)
Charge advice (All calls) *411#
Charge advice (During call) "R"(to hold call) *40#(Call will be reconnected)
Cancel all calls charge advice #411#
Reminder call *55*(Time in 24 hour format)#
Cancel reminder call #55#
Call Divert - all calls - activate *21*(Number to divert to)#
Call Divert - all calls - to check *#21#
Call Divert - all calls - to cancel #21#
Call Divert - on busy - to activate *67*(Number to divert to)#
Call Divert - on busy - to check *#67#
Call Divert - on busy - to cancel #67#
Call Divert - on no reply - to activate *61*(Number to divert to)#
Call Divert - on no reply - to check *#61#
Call Divert - on no reply - to cancel #61#
Call waiting on *43#
Call waiting off #43#
Call waiting - to check condition *#43#
Call waiting - to answer 2nd caller Recall + 2
Call waiting - remove beeps during call Recall + 0
"Ring back" (Camp on busy) 5
Cancel ring back #37#
Caller display on *234#
Caller display off #234#
BT call minder (voice mail) 1571
Check called number 1471
Release CLI 1470 + dialled number
Withhold CLI 141 + dialled number
Access "Choose to refuse" 14258
Call barring on (outgoing) *341 + option number #
(options are 1 = allows 999 and operator, 2 = allows 999 & local, 3 = allows 999 & STD, 4 = bars all operator calls, 5 = bars *, 6 = bars premium adult lines, 7 = bars premium information lines)
Call barring off (outgoing) #341*(PIN code)#
Incoming calls barred off [System X] #261#
Incoming calls barred on *261#
Incoming calls barred off #261*(PIN code)#
Feb 19, 2015 | BT Lands Phones
Why won't phone ring on incoming call?
Has this always happened?
Does it happen every single time? are you in cellular coverage, or does it happen only when you are in certain areas?
Have you got your call diverts set up correctly?
1. Find "Keypad"
2. Choose option
  • Choose one of the following options:
    • Divert all calls, go to 2a.
    • Divert missed calls, go to 2b.
    • Divert if unavailable, go to 2c.
    • Divert if busy, go to 2d.
2a - Divert all calls
  • Key in **21*+61411000321#
  • Tap Call.
2b - Divert missed calls
  • To select how long you want your mobile phone to ring before the call is diverted:
    • Key in **61*+61411000321**the required number of seconds#
  • Eg.:
  • Tap Call.
2c - Divert if unavailable
  • Key in**62*+61411000321#
  • Tap Call.
2d - Divert if busy
  • Key in**67*+61411000321#
  • Tap Call.
3. Return to the home screen
Jun 07, 2014 | Apple iPhone 5c
What is the barring code for Nokia n70?
The @ represents pressing the "Send" key on your mobile
##002#@ all call diverts off
*#06# IMEI Number showing
**004*DestNo#@ set all conditioned call diverts to DestNo on and active
##004#@ all conditioned call diverts (busy, not reachable, no answer) off
**21*DestNo#@ Automatic divert all calls to DestNo on and active
*21#@ Automatic divert all call DestNo activate
##21#@ Automatic divert all calls to DestNo off and inactive
#21#@ Automatic divert all calls to DestNo deactivate
*#21#@ Automatic divert all calls to DestNo status
**61*DestNo#@ Call divert when not answered on and active
*61#@ Call divert activate
##61#@ Call divert when not answered off and inactive
#61#@ Call divert deactivate
*#61#@ Call divert when not answered status
**62*DestNo#@ Call divert if not reachable on and active
*62#@ Call divert activate
##62#@ Call divert if not reachable off and inactive
#62#@ Call divert deactivate
*#62#@ Call divert if not reachable status
**67*DestNo#@ Call divert when busy on and activate
*67#@ Call divert activate
##67#@ Call divert when busy off and inactive
#67# Call divert deactivate
*#67#@ Call divert when busy status
**03*330*oldPW*newPW*newPW#@ Changing the password for call barring
**33*PW#@ Barring all outgoing calls on (PW one row before)
#33*PW#@ Barring all outgoing calls off
*#33#@ Barring all outgoing calls status
**330*PW#@ Barring all calls on
#330*PW#@ Barring all calls off
*#330*PW#@ Barring all calls status
**331*PW#@ Barring all outgoing international calls on
#331*PW#@ Barring all outgoing international calls off
*#331#@ Barring all outgoing international calls status
**332*PW#@ Barring all outgoing international calls except homecountry on
#332*PW#@ Barring all outgoing international calls except homecountry off
*#332#@ Barring all outgoing international calls except homecountry status
**333*PW#@ Barring all outgoing calls on (PW one row before)
#333*PW#@ Barring all outgoing calls off
*#333#@ Barring all outgoing calls status
**35*PW#@ Barring all incoming calls on
#35*PW#@ Barring all incoming calls off
*#35#@ Barring all incoming calls status
**351*PW#@ Barring all incoming calls if abroad on
#351*PW#@ Barring all incoming calls if abroad off
*#351#@ Barring all incoming calls if abroad status
**353*PW#@ Barring all incoming calls on
#353*PW#@ Barring all incoming calls off
*#353#@ Barring all incoming calls status
*43*#@ Call waiting on
#43##@ Call waiting off
*#43#@ Call waiting status
**61*DestNo**Seconds before divert#@ Divert call if not answered for 'seconds' (Note: Seconds must be 5, 10, 15, 20, 25, 30)
#30#[email protected] No presentation of the number of the incoming call (CLIP)
*30#[email protected] Presentation of the number of the incoming call (CLIP)
*#30#@ CLIP status
#31#[email protected] Your number will not be send for the actual call (CLIR)
*31#[email protected] Your number will be send for the actual call (CLIR)
*#31#@ CLIR status
*76#@ Presentation of the number under which I reached the other one (not his number if he has turned on a call diversion!) (COLP) on
#76#@ Presentation of the number under which I reached the other one (not his number if he has turned on a call diversion!) (COLP) off
*#76#@ Presentation of the number under which I reached the other one (not his number if he has turned on a call diversion!) (COLP) status
*77#@ Presentation of the number under which the caller has reached me (not my number if I have turned on a call diversion!) (COLR) on
#77#@ Presentation of the number under which the caller has reached me (not my number if I have turned on a call diversion!) (COLR) off
*#77#@ Presentation of the number under which the caller has reached me (not my number if I have turned on a call diversion!) (COLR) status
Jun 10, 2011 | Nokia N70 Cellular Phone
How to divert call 5530
Call - Divert.This feature allows you to divert an incoming call to a landline or to any cellular. This way you don't miss out on any important incoming calls. Calls can be diverted when you are busy, unavailable or travelling. The call can be diverted to any landline or cellular within the service provider's network area. Calls cannot be diverted to a cellular of another service provider.
From your Handset menu -
* go to call Divert/Forward.
* choose the option you want from the following.
* enter the number you want to forward the call to.
Options: You can choose from 4 types of Call Divert services:
1. Call Divert on "not reachable" : Diverts calls automatically to your chosen number when you cannot be reached - such as when your phone is out of network coverage, has a no battery charge or is turned off.
2. Call Divert on "busy" : Diverts calls automatically to your chosen number when your phone is engaged.
3. Call Divert on "all calls" : Diverts all calls to your chosen number. If this option is set, you will not receive any calls on your mobile phone till you have cancel Call Divert "all calls" facility.
4. Call Divert "if no reply' : Diverts calls to your chosen number when you do not answer the phone for a specified number of rings, (you can define the number of rings).
Hope it helped out.Please don't forget to rate me thanks alot..
Feb 01, 2011 | Nokia 1112 Cellular Phone
Nokia active incoming call diverts problem:
I hope you have activated your call divert function so your are not able to get the incoming calls.
To deactivate the diverts,
Menu > Settings > Call > Call divert > No Call Divert.
Select No Call Divert it will deactivate all the call diverts and now you can get the incoming calls.
Thanx
Aug 04, 2010 | Nokia 6300 Cellular Phone
How does one tgransfer an incoming call from one phone to another?
You don't need a "generic Compaq PC laptop" to do this.
Press the "transfer" button on the base-station,
and then dial the 3-digit or 4-digit "extension" for the person.
Your office PBX (Private Business eXchange) box will handle the rest.
Nov 20, 2009 | Computers & Internet
How do i use the call forward option?
Call forward or call divert, the same features just different names in some models of phones. Only the name of the service says that it is diverting calls. There is 4 situations for activation and can be activated via the mobile device or directly by entering codes on the display phone. The function codes and their ability to use depends on the network operator.
Codes:
** 21 * number that diverts calls with code of network operator # OK, yes or call it will divert all incoming calls unconditionally
##21# ok, yes or call it will deactivate this divert.
*#21# ok, yes or call it will check status.
** 61 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when you do not want or can not answer the call
##61# ok, yes or call it will deactivate this divert.
*#61# ok, yes or call it will check status.
** 67 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when your line is busy ##67# ok, yes or call it will deactivate this divert.
*#67# ok, yes or call it will check status.
** 62 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when you are unavailable ##62# ok, yes or call it will deactivate this divert.
*#62# ok, yes or call it will check status.
##002# ok, yes or call it will deactivate all divert.
If the codes not working you have that option in your phone, it is in call settings. You choose option and then insert a number for diverting calls.
This service is not free, and you must contact your network operator for prices.
By!!!
Nov 03, 2009 | LG VX5400 Cellular Phone
Delete divert on disply
use ##002# to cancell all divert. This will work only in GSM networks.
Oct 13, 2009 | Cell Phones
Tone And Message
Call Divert
The GSM standard knows two kinds of call divert:
  • Unconditional call divert
  • Conditional call divert
Conditional call divert occurs on any of three conditions:
  • Divert if no answer after 'x' seconds
  • Divert if unavailable (cellphone switched off or out of range)
  • Divert if line busy
Furthermore, the GSM standard knows three different types of call:
  • Voice call: normal communications when you pick up the phone to talk to someone.
  • Fax calls: the GSM terminal being called is a fax machine.
  • Data calls: your cellphone is acting as a modem hooked up to a computer accepting inbound data from elsewhere.
Each call type is assigned a number: 11 for voice calls, 13 for fax calls, 25 for data calls.
You can activate or cancel conditional call divert on your device. To do so:
##62# : Cancel divert for all call types
##62*11# : Cancel divert for voice calls
##62*13# : Cancel divert for fax calls
##62*25# : Cancel divert for data calls
This code does not hurt your device only helps it to tell it what to do in certain situation of a voice, data, or fax call.
This is a link to a site which goes a little more in depth with the meaning of conditional/unconditional call diverting is. Hope this helps!!!
Dec 17, 2008 | LG CE110 Cellular Phone
Call Divert wont go off!
Hi guys
That call divert comes automatically, did my nuts in today. Anyway just key this code
#002# , then press the green key, then bingo call divert off.
cheers
Irwin
Nov 12, 2007 | Motorola Mobility RAZR V3x Cellular Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
125 people viewed this question
Top NEC Lands Phones Experts
Ekse
ray gallant
Andrew Taylor
Andrew Taylor
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
