Question about Amerock Hardware & Accessories
Dwd vf80m1 My door hinges of Deewoo dwd vf80m1 is broken. where can I replace it in UAE?
5 Related Answers
retrorecycle
  • 29 Answers
SOURCE: Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Posted on Jan 28, 2008
Anonymous
  • 43 Answers
SOURCE: Replace door hinge on JVM1533WD002
Door Hinge replacement requires a Microwave Radiation Leak Test be performed after repairs.I am surprised they would sell you the part knowing this. You should have this repaired by a professional for SAFETY sake.
Anonymous
SOURCE: Door Hinge replacment
have you tryed taking the door screws out and put the new one in
Posted on Apr 02, 2008
gittos73
peter gittos
  • 247 Answers
SOURCE: door hinges broken and door fell off
yeah very easy and it should only cost at most about £10 undue the old hinge with the 2screws now the door will have two little covers that held the old hinge in place take these out and make sure u get the broken pieces out of them once u have the new 1 put it on the washer and screw down first and then place the covers on the ends of the hinges and put the door in place now redue the screws on the door
Posted on Jun 04, 2008
Puppet03
Puppet03
  • 172 Answers
SOURCE: Hinge for the Cartridge Door will not latch. Seems
good old duck tape ;) or go to a print repair shop and see if they have and parts for you.Ink shops sometimes do there own repairs too so try there
Posted on Oct 24, 2009
Testimonial: "Thanks I did not know the Ink shops could do repair. "
How do I know if the hinge is broken on the stove door?
the door will fall off when opened if both hinges are broken, if only one hinge is broken the door will drop down on one side.
Apr 20, 2012 | Brown Stove Works Ovens
My nikon coolprix camera l14 battery compartment door broken. can I repair it in Abu Dhabi, UAE
ITS A TOUGH JOB TO FIND A REPLACEMENT . THE ONLY WAY YOU COULD DO IT IS TO USE A ADHESIVE TAPE OVER THE DOOR TO FIRMLY HOLD IT IN PLACE.
REGARDS.
PLZ. DON'T FORGET TO RATE THIS COMMENT.
Jul 07, 2011 | Cameras
Have replaced broken hinge but am stuck getting both fridge and freezer door back on. can do one or the other but not both. westinghouse freestyle fridge/freezer
srack from bottom up- bottom hinge - bottom door- tape door with duck tape- middle hinge- top door- tape top door- top hinge- remove tape- done
May 25, 2011 | Refrigerators
Door hinge on hygena single electric oven broken
You neede to replace both door hinges.
To get more detailed instructions on how to do this, go to the following site.
WWW.YOUTUBE.CO.UK
In the search box enter FITTING OVEN DOOR HINGES.
You should then click on the appropiate link, and follow the instructions.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Ovens
Trunk door hinge like x-bar was broken, what if i
dear friend-it will be ok to weld the hinge
Nov 09, 2009 | 2004 Volkswagen Passat
Broken door hinge replacement on Hotpoint Ultima
Remove all the screws securing the 2 door halves together, and gently prize apart the two halves with a screwdriver or similar, be careful not to drop the door glass.. You will probably be better off removing the door from the front of the m/c altogether.
Replace broken parts as req'd.
Plz rate my solution
Thanks.
Dec 27, 2008 | Hotpoint Ultima WD72 Front Load...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
my door indicator light wont stop flashing the door is locked
Mar 05, 2008 | Creda W100FW Front Load Washer
Jan 28, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Hardware & Accessories Logo
50 people viewed this question
Top Amerock Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an Amerock Hardware and Accessory Expert? Answer questions, earn points and help others
