My kenwood krf-v5100d left and right front audio won't work
There is a balance option. Find the manual for this player and look for balance. You are looking to change it to 0 so that it plays through all of your speakers at equL volumes
Testimonial: "yeah they are all on 0 i have gone in to all the settings and cant fix it i don't know how come there is a pic of a Kenwood KRC-379R Cassette player it's a av amplifier but thanks anyways"
SOURCE: Kenwood KDC-BT838U -- Low audio on incoming phone calls only.
Patrick -
I have the reverse problem. Callers can hardly hear me.
I saw a setting in the headunit that allows you to specify where the audio plays for incoming calls. You can choose the Left Front Speaker, the Right Front Speaker or Both. Check the manual and make sure its set to both.
Regards,
Charlie
SOURCE: Volume turned up, kenwood shuts off briefly...
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
SOURCE: Kenwood kdc-mp528 amp/speaker problem???
This is a common mistake. This problem indicates that you are using the solid blue wire from the head unit to the remote turn-on on the amp. This is a power antenna wire that only receives power when on FM radio. You need to replace this with the Blue & White wire from the head unit (power control wire) to your remote turn-on on your amp. This should solve your issue.
SOURCE: Head Unit of boat stereo cutting out at higher volume
check your ground wire ..
then check battery has enough charge..
usually fault is in where your stereo is connected to your ground source.. good luck ,if no luck try your checking your speaker wires for a short..
SOURCE: how to Fade individual speakers on the Kenwood
Hi.
Use the audio control settings. Here an extract from manual:
Here the full manual:KDC-4020 KDC-3020 KDC-2020 KDC-1020 KDC-1020S.
Regards.
Ginko.
Testimonial: "Thanks Ginko, Just what I needed, Thanks heaps Regards John"
