One day out of the blue my Kurio 4s died. so I tried to charge it but it won't charge! It has been 5 months!!!!! I tried buying a new charger also. Please help!!!
Hi, quite a few things could be the problem, 1, the battery has died....which can be revived with the proper machine, 2. depending on age, it needs to be replaced, 3. your charging port is faulty and needs to be replaced, 4. the wall plug you use can also be worn out and does not make proper contact.....I would suggest that u rather hand it in to a bona fide technician.....
Well that happend to me i plug it in the wall outl et but the charger is a little loose so you might've had you move it around until it shows that battery the goes from red to yellow and from yellow to green
