Look under the hood. you should find a part under there with two metal thin lines connected to it so that when you push the gas pedal, that part moves up, when released, it should go back down, have someone press the gas pedal and look for it right on top of the engine. is there something blocking it? wiring harness, etc.?
press and hold start button without pressing brake pedal. do not release until all lights come on and go off except SES light. now press gas pedal three times in five seconds. turn off ignition.press brake pedal and start vehicle. thats it
shut the car off and look at the throttle body, have someone step on the gas pedal if the throttle body does not open up then the cable from the pedle to the throttle popped off or broke
fords/international have pad pedal position/throttle position sensors that go bad and you can replace the sensor or the entire pedal but does anyone know what the other sensor is underneath the tps. an accelerator switch??
