Question about Globe Food Equipment Globe C10 - Chefmate Economy Slicer - 10" Blade - Compact
Why would it Hum when turned on
I have a Globe Gravity Feed Slicer. I believe it may be model 150, though not sure. When it is turned on, it hums. If you rotate the blade a moment before turning it on, then the blade will move. Yesterday, an employee said that they saw smoke come from it. What needs replaced and where can I find it.
Posted by Terri Migliaccio on
How to remove berkel slicer blade
my berkel slicer model 818 the motor runs and the automatic table will slid but the blade does not torn
Jun 01, 2012 | Berkel 827E Gravity Feed Deli Meat Slicer
My slider arm wont move
Hi Are you talking about the meat pusher or the arm that you push on to push the meat though the blade ?
Sep 18, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
Do not have model #...older slicer. need to remove blade to clean behind
there is a thru bolt on the left side of the slicer if you are facing it to use it, that holds the plate on, unscrew it, its usually red
Sep 07, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
Guard
I'm not certain this is the same model I'm thinking of, but I think there may be a knob on the back side (behind the blade) which clamps down on a shaft coming off the blade guard. Loosen the know and the guard should pull straight off. Maybe I'm thinking of a different model slicer, but the photo looks correct.
May 19, 2010 | Berkel 827E Gravity Feed Deli Meat Slicer
Globe Meat Slicer Model # 500 motor runs blade not turning
Fiber gear on blade hub stripped. deep socket required to remove hub. DON'T CUT YOURSELF!! remove motor, used food safe solvent to clean grease out of housing. Fiber gear held on with snap ring. Replace gear, repack housing, put hub and motor back and start slicing. Routinely check to make sure gear is lubed.
Oct 30, 2008 | Berkel 827E Gravity Feed Deli Meat Slicer
Globe Food Equipment Globe C10 - Chefmate Economy Slicer - 10" Blade - Compact Logo
880 people viewed this question
Top Globe Food Equipment Home Experts
john h
Tom Chichester
Are you a Globe Food Equipment Home Expert? Answer questions, earn points and help others
