Question about Cooktops
I have just moved into a new apartment in France, and we have a 2 ring touch screen hob. There are no instructions or booklets but it says "Schott ceran brandt" on it. It works, as I've worked out how to set the safety lock, and both rings turn on, and we can change the temperature....but they are not giving off any heat? What am I doing wrong? I have turned on each hob, tried all the heat settings, and nothing happens! Please help!
Posted by Sarah McNeice on
shannon816
    Habit-Forming:
  • 52 Answers
I presume that you have a induction cook top. if so not all pots and pans will work on them. i have never had one but i do know this could be your type of problem. do some research on what pans to use on a induction stove.
Posted on Jul 02, 2017
4 Related Answers
Maytag317
Victor
  • 1136 Answers
SOURCE: TOUCH CONTROL HOB (SCHOTT CERAM) GLASS CRACKED
Hi. Yes you can buy a new glass. Most of the come with frame top now. If you get me the model # I can look this up for you and get you an idea on cost.
Vic
Posted on May 18, 2009
Anonymous
SOURCE: I have just moved homes and never used a ceramic
If your hob is siemens then the controls are touch... press the on/off switch for power, then the control pad is yours with
Posted on Sep 07, 2010
Anonymous
SOURCE: i have a bosch schott
press and hold the power button for a min.
Posted on Dec 19, 2010
Jeff Caskey
  • 20 Answers
SOURCE: I have a Schott Ceran Induction hob and one ring is locked with a flaching E then 4. Any ideas how to fix this?
Try pushing the - (minus button) for more than 3 seconds and see if it unlocks. If not contact them here:
http://www.us.schott.com/hometech/english/contact/mail_form.html?mail_model_type=WSS_Contact&mail_model_id=965044006&referer=/hometech/english/products/ceran/index.html
Posted on Feb 08, 2012
Schott glass hob keeps flashing L on each ring why
Glass hob keeps flashing l on each ring why????
Nov 21, 2011 | Cooktops
Bosch Ceran Schott hob. Number in top left corner
We have this exact same problem, and I've not managed to track down a manual (we rent and the landlord is on holiday).
I've tried holding down all buttons for a time, combinations of buttons, and turning it off at the mains, but no joy.
Did you ever solve this?
[submitting this as 'post solution' but there is no button for 'say you have the same problem'!]
May 27, 2010 | Bosch Cooktops
Eurokera hob - lights flashing, buttons not working
hi i have a eurokers ceramic hob and it has not worked in about a yr. it is touch screen and only 1 mth old when problem happend it was like it over heated and now when you turn it on it flashes on the dial i cnat make out it and the hob wont come on. pls help it is brand new and dont want to throw it out.HELP PLS
Dec 26, 2009 | Cooktops
Vic
May 18, 2009 | Cooktops
Got a diplomat ceramic hob with no instructions
If the KEY lock is on (key botton flashes when switched on) ... touch AND HOLD the lock symbol for AT LEAST TWO seconds until it beeps, then hold the on/off button for AT LEAST 2 SECS.
If the CHILD lock is on ([L] on all displays when switched on), then:
1)Hold the on switch for TWO secs min (unit swtiches on) ...then
2) touch AND HOLD the + AND - for AT LEAST 2 secs
3) touch the - button once again.
Jan 14, 2009 | Cooktops
Whirlpool Oven, Ceran stove top
I want to say that since I posted my original problem with black spots appearing on the Schott Ceran top, I took pictures of the top and attached them to a complaint sent to Maytag. Approximately 3 days later, a Maytag representative phoned and offered a brand new top-basically stating that there is a fault with the tops. They would not pay for the labor to replace the top. My husband downloaded the instructions from Maytag website and installed it himself. These spots actually appear from within the surface and are not the result of a boil over, etc. The spots on my burner grew to the width of the burner. If you search the internet, you will see many others with the same problem with the Schott Ceran tops. I will never buy another!
Nov 20, 2007 | Cooktops
Cooktops Logo
443 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
