Cameras Logo
Question about Canon PowerShot Cameras
Canon A2200 black screen
Black Screen
5 Related Answers
Anonymous
SOURCE: Canon Powershot A70 black screen
Thanks! Found this while searching the web for the same problem. Canon is now repairing my 5 year old camera.
Posted on Aug 27, 2008
Anonymous
SOURCE: Black Screen
I am checking out the following :
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Posted on Feb 02, 2009
t00nz
CameraR
  • 4738 Answers
SOURCE: Black screen problem with Canon PowerShot SD 750
Did you accidentally press the DISP button on the back of your camera? This manually turns the screen on and off to save batteries. Try pressing this button one more time to see if it turns the screen back on.
Posted on May 27, 2009
Anonymous
  • 5 Answers
SOURCE: Canon SD1000, screen blacked out and takes black pictures
try taking the batteries and memory card out let it set and put everything back in it ang cut it on
Posted on Jun 18, 2009
Anonymous
SOURCE: canon ixus 75 black screen
I tried all the solutions offered on the net and none worked except one. It simply said "hit the camera with the palm of your hand" (when it is on) and the screen will return. I thought, well I have nothing to lose and so I hit it on the side and sure enough the LCD is again working !!!
Posted on Dec 20, 2010
Why wont my canon powershot a2200 turn on after i dropped it
I think you answered your own question there. There is a chance that the battery or memory card is not seated properly after the fall so you might try removing both, let the camera sit for 15-30 seconds and reinstall the battery/card and give it a go. Otherwise, there's most likely internal damage and the camera will need to be repaired or replaced.
Canon a2200 screen
The LCD screen inverter maybe faulty. Take your camera to the Canon repairer to have the camera fixed.
I have A2200 cannon powershot camera but the flash is not working
You can Google your camera make/model and open the link to download your user manual in a PDF. I did this and picked the one below. Under the Table of Contents, pick Turning off the flash. The instructions to turn it on are there as well.
Hope this helps. Mike
CANON POWERSHOT A2200 USER MANUAL Pdf Download. www.manualslib.com > ... > Digital Camera > PowerShot A2200
View and Download Canon PowerShot A2200 user manual online. PowerShot A2200 Digital Camera. PowerShot A2200 Digital Camera pdf manual download.
When I turn on my camera I get a black screen
The camera is either set to a power save mode or the screen has failed.
Check your user guide for power save settings, if you don't have one, you should be able to download one from here:-
http://www.canon.co.uk/For_Home/Product_Finder/Cameras/Digital_Camera/PowerShot/PowerShot_A2200/
1helpful
I have the canon powershot a2200 and the screen is just black as well as my pictures
okay 1 of 2 things is wrong i think A) the lens or that area is broken some where B) the screen is broken what you need to do is send it to canon so they can tell you what the problem is
if the screens broken buy one off the internet open the camera using a eyeglass screw driver or you will strip the screws look how the screen is connector flip the switch and take out and replace you screen the video that i have linked isn't your camera but the assembly and disassembly should be the same and so the screen changing i cant help you if its problem A) my only advice buy a new camera if cost effective or get it repaired
Black screen when I try to record ,but the sound is there
Title :Canon ZR 60 Black Screen in Record mode
Question : Can Canon Repair this defect ??
I have found several other people with the same problem Canon ZR60 won't record ,only get a black screen ,only a few years old with less than 75 hours use .Can this be fixed free from Canon .
[email protected]
Goce
MAKEDONIJA
Top Canon Cameras Experts
old marine
old marine
Ekse
David Shaub
Are you a Canon Camera Expert? Answer questions, earn points and help others
