This is usually a Word option.
In Word versions prior to Word 2007:
1.Click the Tools->Options menu item.
2.Select the Print tab.
3.Make sure Include with document/Document Properties is DEselected.
4.Click OK.
In Word 2007:
1.Click the round Office button in the upper-left corner of the window.
2.Click the Word Options button.
3.Click Display.
4.Under Printing Options, uncheck Print Document Properties.
5.Click OK.
SOURCE: Canon MP730 won't print at all (blank pages).
try to move the blue nozzel over the printing head to the from the right to the left and try, it will work
SOURCE: Canon i560 won't print black text anymore
I have now found the solution elsewhere in the internet: black text only prints on the Canon i560 if selct "normal paper", but not,for instance, if you have "professional photo-paper" selected.
SOURCE: canon IR C3220 cannot print multiple pages..ONLY able to print one page
The answer depends upon the printer controller that your 3220 has. There are at least 3 controllers & probably twice as many versions for the assorted printer controllers. The key is do you have a Fiery (Little white box hanging on the back) or does the network connect directly into the NIC on the upper left corner of the copier. Drivers with -C1 or -C2 connote a Fiery printer driver. I would advise using the PS drivers if this is the case as the Fiery is much better at PS than PCL. Another way to tell if Fiery is on copier is scroll to right on LCD panel & see if there is a "Printer" screen. If so you can go in to "functions" "Print Pages" & print a "Configuration" page. this will show you the network ip#. Put the # in your web browser (no http:// etc needed) & you can download the correct drivers for Mac / PC right from the device. If no Fiery is on the device stick with PCL5C drivers as they are usually the best for Canon PDL board print controllers.
