What is the problem you faces with this TV? Provide more details, please. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
SOURCE: I have SOYO MT-+SYTPT3227AB TV
This TV is not Wall Mountable as the Control Box protrudes and is therefore not suitable for a VESA Wall Mount.
SOURCE: Soyo Television Model MT-SYT PT3727ABMS
Sure thing, I found that for you. It is part # FSP190-4F03. I found it online at the link at the bottom of my answer here...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://www.shopjimmy.com/fsp-fsp190-4f03-power-supply.htm
Thanks
Tim
SOURCE: what is the remote learning code for my 32" TV
Mounting an LCD (Liquid Crystal Display) TV on the wall may seem a bit overwhelming at first; but it's not that difficult. With a few simple tools, a proper mounting kit and a helper, the job will be a breeze. With a little bit of patience and an hour or two, your LCD TV will look great. Follow these steps to learn how to mount an LCD TV on the wall.
Things You'll Need:
LCD TV
Mounting kit
Tools
Step 1
Find the best spot on the wall to mount the LCD screen. Think about how much room you may want on that wall, especially if you plan on mounting speakers, too. You could hang a poster or picture relative to the size of the television on the wall to see if you like the placement.
Step 2
Pick a mounting kit. You can purchase mounting kits online (see Resources below) along with many other sites. Look to make sure the kit and TV are VESA compatible so that you have standard measurements and quick, easy attachment during the mounting process.
Step 3
You may already have tools needed to mount the TV. You'll need a set of screwdrivers, a socket set, a saw capable of cutting into drywall, a drill and a measuring tape. Having a stud finder with a built-in level is also great to pinpoint the exact location of the stud. The stud finder will be useful if you'll be running wires through the wall.
Step 4
Get the location for the TV picked out. Check near the bottom of the wall to see if the area you plan on using to run the wires is free of obstructions. Using the stud finder for this will make it easy.
Step 5
Find the studs. You should use at least one stud when mounting the LCD screen to make sure that the mounting bolts are driven into something solid that will support the weight of the TV and the mounting bracket. Using two studs is ideal for mounting larger TV's, those with screens larger than 37 inches. Use a pencil to mark the drill holes for the anchors and stud location.
Step 6
Secure the mounting rails to the back of the LCD screen. Double check them for proper fit. Make sure that they're hidden behind the body of the television for a finished look.
Step 7
Cut the hole for the wires to come through by using a drywall saw. The easiest way is to pull them out at the electrical box. This avoids having to go into the basement, closet or otherwise. You can purchase a wall box at your local home improvement store to place in the exit hole of the wires.
Step 8
Drill the holes for the bolt anchors in the locations that you measured and marked previously. Place the bolt anchors into the holes and tap them in with a hammer.
Step 9
Secure the wall mount to the wall. You'll need a socket wrench to ensure that the mounting bolts get snugged down tightly to the anchors. Use a level to make sure you've done an even job.
Step 10
Grab a friend or family member to help you lift the LCD screen onto the mount. Make sure it's locked down tightly and the screen is set to go.
Hope this helps and Good luck
SOURCE: i have a 37 in MT-SYTPT3727ABMS tv power comes on and sound but no picture please help
Audio but no pictureb>This is a common issue in many LCD or Plasma sets andit does not have a common solution.In most cases you need to first check for missing voltages on the power supply board and for damaged caps there. If good voltages exist then look elsewhere.LCD (not projection) sets often use a back light to provide the light source for the screen unit (display panel) so confirming the voltage for those is first-if back lights are used but not on it is either no voltage, not being turned on by the set, or bad light unit/s.In these sets there are also boards that "Drive" the panel itself. Usually the set will use two boards (some combineboth into one large board---names vary but are Inverters, Y-boards (Y means video) T-con boards etc. Usually in this case only one half of the screen will be black but it is possible for it to cause a total loss of brightness also.Plasma sets are similar to some degree but with no back light in most cases.Trouble shooting can be tedious and expensive-Taking one of these sets apart requires some skill as one wrong move and the Display panel can be instantly damaged which is fatal from arepair cost point of view.Other possible solutions include but are not limited to physical problems---loose plugs or connections (look for any plugs held down with tape where they plug into aboard). A lot of people with problems play the guessing game-buy and try a board after research which can get expensive and may not fix the set---gamble or not?I have seen sets where every single board was replaced and set still did not have a picture-means display panel is the problem.The problem can even be the "main" board in some cases -it controls the communication with the panel and if faulty can cause issues.Aside from checking voltages, connections etc. there are afew other considerations---The problem can be the display panel itself---Part cost for that is more than the set cost when new.The panel connects to the boards that drive it with either a multi-pin conventional plug or a RIBBON CABLE.The worst case is the problem is a ribbon cable etc. bad or damaged INSIDE the panel where it cannot be got at.That means if the case set would cost too much to repair.The connectors where the cable attaches outside of thepanel can also develop dirty or loose connections.Fans in units that use them can be an issue if dirty or not moving.As you can see (or not if no brightness) the problem sounds simple but has many possible different causes.Let me know if you have questions as I am here to try to help.SDTECH
