SOURCE: Connecting a netgear wireless router to a 2wire
before you connect the netgear router to your 2wire modem, you have to get the modem configured first. you did not include the firmware version of your modem (firmware version is found at the UI, go to gateway.2wire.net, click on the system icon.) for firmware version less than 3.7, go to homeportal/management, click on configure services, uncheck enable routing, then click on submit. for version 3.7 or higher, go to homeportal/management, click on configure under broadband link, put a dot in disable pvc search, set VPI to 0 & VCI to 35, the connection type box should be direct IP, then click on submit. then go to configure services, uncheck enable routing box, then click submit. you will notice the broadband link on the 2wire modem turn orange/amber, then you have successfully set the modem to bridged mode. that way you can now connect the router according to manufacturer's instructions (or just read the manual for the netgear router....)
The USB port of the My Cloud is designed to be used as an extension port. You may use it to attach another external to the My Cloud or device like a camera. If you prefer cable connection between your PC and your My Cloud, I would recommend you to use an Ethernet cable.
http://community.wd.com/t5/WD-My-Cloud/Connecting-My-Cloud-to-MacBook-Pro-directly-with-Ethernet/td-p/717882 - Check this similar topic in the official WD community.
Hope this helps
