The first problem was it wouldn't drain/spin. Now it won't start a cycle at all. When I press the start button once, it beeps. The start light flashes and the wash, rinse and final spin lights come on. When I press the start button again, it sounds like the door lock engages, but the start light begins flashing and nothing happens. What could be the problem(s)?
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
Posted on Jul 23, 2014
SOURCE: My Ge wssh300gww will
It is probably a clogged pump (don't look in owners manual for info - curiously it isn't in there - just says call tech - bolocks!)
Remove 2 screw on front bottom panel.
Remove cover.
Plastic boot and pump are on right had side. Clean out - and use the change to buy a drink - celebrating the fact you didn't have to spend hundreds on a tech!
Posted on Aug 25, 2008
SOURCE: he2 washer flashing code f51
check hose inside mine had two baby socks clogging it up
Posted on Feb 14, 2008
SOURCE: Door Lock LED flashing
The solution from testy helped me but I decided to change it.
I cut the plastic latch away from the end of the interlock,just the little bar that holds the door closed.This means that the lock position doesn't affect the door.
I then used the little piece of plastic to act as 2 packing pieces to hold the lock half closed. This works fine.
Don't push the lock fully closed or it doesn't work
Posted on Nov 29, 2008
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
SOURCE: I have a Frigidaire washer model FTF2140ESO that
I've had this happen before. Try unplugging it and leaving it unplugged for about five minutes. Plug in and try again.
Leslie
Posted on Oct 09, 2009
Jan 03, 2015 | Whirlpool Washing Machines
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Oct 17, 2011 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Sep 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Sep 05, 2009 | Washing Machines
Jun 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Mar 04, 2009 | General Electric WHDVH660H Front Load...
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Feb 28, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Mar 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
582 people viewed this question
