Question about Electrolux Dishwashers
The anti-flood system has been triggered on ELECTROLUX ESF 656 how can I fix it?
The anti-flood system has been triggered on my dishwasher,how can I fix it?
Dado
    Master:
  • Electrolux Master
  • 511 Answers
The anti-flood system has been triggered means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Dado
Posted on Jan 14, 2015
5 Related Answers
yalmer
Hjalmer Lamminen
  • 552 Answers
SOURCE: anti flood system has been
Copy and paste to your browser.
www.serviceforce.co.uk/pdfs/U27431.pdf
It will download to your computer and these are the instructions.
Posted on Apr 22, 2008
Anonymous
SOURCE: anti flooding system
yes I will for $14.99 !
Posted on Aug 28, 2008
joe_lishman
Joe Lishman
  • 192 Answers
SOURCE: warning lights flashing for Anti flood system
The bottom "Y" 3 point hose at the bottom connected to main motor is of poor quality and does have 3 wire clamps. The hose does perforate and small pin hole causes water at the bottom to trigger the anti flood system with warning lights flashing and pump motor on ...
Posted on Jan 16, 2010
joe_lishman
Joe Lishman
  • 192 Answers
SOURCE: Anti flood system triggered Favorit 40660 dishwasher
The problem was solved by opening the machine and finding that the bottom "Y" pipe that has 3 inputs is of extremely poor quality and perforates with pin holes allowing a small amount of water to squirt out. This triggers the anti flood and error status lights flash. The outlet pump is activated and machine does not do anything. You need to replace this hose or like I modified it to work from a 32mm Y plastic junction available from most hardware shops. The wire clamps for this was replaced by "jubilee" screw tight clamps.
I worked on a table and also removed the "Brick" placed at the bottom for balance purposes by cutting the back plastic down with a saw. This made the job very easy...
Posted on Jan 17, 2010
Testimonial: "Thanks, this was the correct answer and solved the problem. "
Anonymous
SOURCE: dishwash machine electrolux esf 6121
Easy fix, had same problem on our. behind the red lights there is the electrc stuff, when you open/close the machine the solderings crack. remove screws until you can get off the panel, then there is some small hooks that hold the board, loosen all contacts and take out the board, check the solderings around the relais and re-solder them, i resoldered all spots on our board.
Posted on Jul 24, 2010
Anti flood stuck on
Turn the water back on at the wall.
Aug 20, 2012 | Dishwashers
Water wants to drain and keeps trying
Sounds like anti flood system has triggered (polystireen float and micro switch) that puts the washer in pump out mode only and shuts the inlet water off. You need to look at the bottom of the washer and check that water leak / spill is not causing the float to activate. Clear the water and fix leak (pipe or pipe clamp) and this should fix the problem.
May 18, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
The dishwasher fills up it starts to spray the water but after 5 seconds it emptys. It then does the other the rest of the wash normally. This happens in all modes.
Check to see if water at the base of the washer has caused the "anti flood system" to trigger. The anti flood device is a polystireene float and micro switch that does trigger (and puts the washer in pump out mode) once water via leak or spill is detected. You can tilt the washer to 45 degrees and check if a small amount of water comes out of the bottom. As you indicate that the washer emptys after 5 sec I do think that the anti flood system is causing this.
Apr 21, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Water won't come into the dishwasher
The anti flood system could have been triggered due to a water leak or spill at the bottom of the washer, This device (polysireene float and micro switch) when triggered shuts off the inlet water and puts the washer in pump out mode only. Use a torch and check if a small amout of water is causing the float to trigger the microswitch attached to the float. If a small amount of water leak / spill is causing this you need to first fix the spill / leak. before you try again.
Apr 21, 2010 | Crosley 24 in. CDU600 Built-in Dishwasher
Aeg favorit 64070vi, i 30 fault, think that the anti flood switch is triggered
Thanks to all.
What we couldn't work out is what is actual mechanism of anti-flood triggering, and how therefore to reset it - and why all these other fixes work - but then it occurred to us, that problem is when water gets into the base and can't get out.
Our problem was that water inlet at top of washer came loose so water ran down outside the drum but inside the dishwasher, into the base. We tried the tipping method but this just moved water around and I think there must be sensor there which, if it stays wet, leaves anti-flood triggered.
This makes sense because other high level overflows from drum discharge into base - so if it was to overflow, it goes into sealed base only, wets the sensor and triggers anti-flood.
Our solution was patience - tipped it fully on its side, pointed a hot air blower into it for hour or so, then left it overnight. Tipped it back next morning, water which had run into side panel ran out, so it was upright with its base dry - and (touch wood) it worked like a charm.
Feb 09, 2010 | AEG 23 in. Favorit 88070IM Built-in...
Water wont come through the dishwasher.i checked the water supply switch it is still in the on position what should i check next.
The anti flood system could have triggered (due to water on the base of the washer via leaky pipe) This device shuts off the water supply and puts the pump out motor on and nothing els happens until you clear the water on the washer floor and rectify the leak.
The anti flood device is a polystireene small plate with a micro switch on the bottom floor of the washer.
Jan 19, 2010 | Dishwashers
Jan 13, 2010 | AEG 24 in. Favorit 40660i Built-in...
Warning lights flashing for Anti flood system triggered and dishwasher not operational
Dec 21, 2009 | AEG 24 in. Favorit 40660i Built-in...
Aeg favorit senorlogic three beeps and no evidence of problem but dishwasher won't work
Anti flood system triggered that puts the machiene in pump out mode. This machiene has a poor quality "Y" pipe at the bottom that is prone to pin holes in the pipe due to poor quality and extremely thin. The pin holes cause a small amount of water to activate the Anti flood micro switch on the polystireen float at the bottom of the washer.
Nov 22, 2009 | AEG 24 in. Favorit 40660i Built-in...
Antiflood system triggered-how to reset on aeg favorit 35080vi
Hello everyone. Have just fixed a problem with my aeg dishwasher thanks to this site. My anti flood switch in, so I unpluged, pulled the machine out, tilted it, wiggled the outlet hose, which I think was a little kinked and way hay it works. Thanks FIX YA. Good luck everyone. Carolyn
Feb 08, 2009 | AEG 23 in. Favorit 88070IM Built-in...
Dishwashers Logo
Top Electrolux Dishwashers Experts
Mike
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
