Question about Siemens Gigaset 8825 Cordless Phone
The lights on the base station are not working. Yes, I have checked the owners manual.
Posted by Sue Post on
Harrie
    Top Expert:
  • Siemens Master
  • 6,746 Answers
The power supply of the base station is working correct? the cable from the power supply is not broken? and the cable from the power supply is inserted?
Just a few questions, things I would start with when my base station wold not have any lights.
Oops the base station of my Siemens Gigaset S79H does not have lights.
Posted on Jul 22, 2014
I have a new weathr station and can not get the outside temp. to display what can I do?
I assume it is a wireless station. If so, there is a procedure to go through to get the temperature sender and the base station to sync up and work. You need to check your owners manual to get the exact procedure for your unit. On my station, I have to remove the battery from the base station, let it power up and within 5 minutes, install the battery in the remote station(s) (temperature, rain gauge, wind gauge, etc.). Also, you must keep the remote station within a certain range for the base to get a good signal. Probably 25 feet, but the owners manual will have the right number. Also, use new batteries.
Aug 02, 2016 | Oregon Scientific WMR86 - Backyard Pro...
I just bought the Panasonic KX-TG9341T. This model has 4 remote extensions. My problem is the light on top of each phone keeps blinking. I checked to be sure I don't have any messages or anything else,...
The message indicator lights up when you have a new voicemail message, answering machine message, when you are receiving a call, or when the handset is placed on the charger. You can change the setting for the voicemail indicator and message indicator by pressing [MENU], [#][3][4][0], and press [▲] or [▼] to switch between off and on, then select [Save]. It is not possible to turn off the LED for an incoming call, or while it is on the charger.
Good luck...
Sep 05, 2008 | Panasonic Lands Phones
Why is the base station not working when the power supply is good?
It is highly unlikely that you will be able to buy just a new base station from the original manufacturer. If you are still covered by the warranty, return the unit and try to claim a brand new unit.
Try taking a call even though the red light doesn't work. Sometimes, the bulb can be faulty. This however, shouldn't prevent you from making a call
Oct 12, 2014 | RTX DUALphone 3088
Atlinks USA model 25951EE3-A records messages but does not ring or give dial tone on cordless handsets. Was unable to find online owners manual.
Place the handset in the Base station - NOT the Remote Charger. Wait 10 seconds for the phone to bond with the base station. The display will go on and off twice. Remove and you are on the way. Toy can do this for up to 4 phones I believe.
You will have to do this every time the the lights flicker or go out.
Also, press Menu on the Handset and use the + and - Keys at top to navigate through menu. Use the * key to exit.
TIP: If the lights quickly go off and on and the Answerer seems to be fouled up. Unplug the Base station for 10 seconds and plug it back in. All will be well again.You will have to re-bond the remote phones.
Jan 24, 2010 | Uniden Cordless Phone
Router stopped working altogether
You can try doing a master reset. (must refer to owners manual on how to) or replace the entire unit. Most likely the unit has failed.
Thanks, Frank
@Tech
http://www.attechcomputers.co.cc
Apr 02, 2009 | Microsoft Broadband Networking MN-500...
Reconnecting Wired Base Station MN-100
Yes, that is possible. Since you have changed providers, you have to reconfigure the router depending on your new provider.
You can try these steps:
1. Turn off the the router, modem and the computer.
2. Wait for 30 seconds then turn on the modem and make sure that all (if not most) lights are stabilize
3. When the lights are stabilized, turn on the router and wait for the lights to stabilize.
4. When both the router and the modem are stabilized, you can turn on the computer and check for the connection.
If it still does not work, you may need to configure the router based on the settings needed by the service provider that you have. If you wish, inform me of the name of your service provider and I will give you the specific settings on how to configure your router.
Sep 17, 2008 | Microsoft Broadband Networking MN-100...
Merging 2 siemens gigaset 4215 systems (one base with 2 phones + 2 phones)
If you're trying to get 5 handsets to work with one base, it won't work. The 4215 can only handle 4 handsets, the base handset plus 3.
When I had to replace the base of my 4 handset system, the base handset still worked. Therefore I had an extra handset which couldn't be used. So I decided to buy another base. Now I have 6 handsets which can be grouped 4,2 or 3,3.
Jun 15, 2008 | Siemens Gigaset 4215 Cordless Phone
Audioline cordless phone
answering machine not working on the base station
Jan 13, 2008 | Philips CD6452B/37 Twin Cordless Phone
Siemens Gigaset 8825 Cordless Phone Logo
132 people viewed this question
Top Siemens Lands Phones Experts
Marvin
Marvin
Bruce Robin
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
