Question about Neff U1421 Double circotherm Electric Oven
Neff oven wiring diagram
Which wire goes to which terminal of the element 2 wire one red one blue
Posted by Michael mahoney on
Hans Pearson
  • 2,510 Answers
It does not really matter which wire goes where. The red one would be live and the blue would be neutral, but on an oven element they could go on either terminal. Just make sure that everything is turned off when working on the oven etc.
Posted on Jul 22, 2014
5 Related Answers
Anonymous
  • 75 Answers
SOURCE: Neff Fan Oven Element _U1661
hi there green and yellow is allways the earth connection which is usually the middle tag, what are the colours of the remaining wires and how many are there???
Posted on Feb 09, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: what is the wire conection sequence
If there is no earth wire to the element, then it it does not matter which wire goes on the terminals of the heater, as they are common, so,as long as you do not connect the wires to earth, it will be o/k.
If one wire is green/yellow, then that goes to rearth.
Hope this helps.
Posted on Dec 22, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Have had 4 Neff oven elements in 2 years.
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Thanks.
Posted on Feb 07, 2010
Roipatrick
  • 906 Answers
SOURCE: Neff B1721 oven
good day,
hope this link below will solve your problem.
kitchen appliances
Posted on Jul 31, 2010
Roni Davey
  • 414 Answers
SOURCE: i have changed the element on a neff oven,the wires came off when i unscrewed it from the oven,i have taken the back off and there are 3 white cord type wires,2 of which have a red stripe and the 3rd
All the red stripes on one side, single (if you look carefully should have a black fleck in the cream cord type covering) on the other side.
Posted on Apr 13, 2013
Neff 1541 not heating with replacement element
Yes two red flecked on same terminal and the black flecked on the other side terminal of the element. Bobs your Uncle......HEAT! Make sure they are a tight fit. New spades if required.
Oct 03, 2017 | Neff Ovens
The grill (Upper Oven Grill Element) in the oven is not working, I realized the 4 wires at the back that connect to it are all loose. Can i fix it by connecting them myself? is it something dangerous or...
With 4 terminals, it sounds like a double grill element. But it could also be a single grill element with a second oven element. If the spade connecters are loose they need to be tightened first. Get a pair of pliers and gently squeeze the terminals until the gap reduces so when it slides on it will be tight. Do you know what wires go where? If so reconnect them. If you don't do the following;
As you look at the element terminals they should run horizontally. Look at the element inside the grill compartment. From left to right, the no. 1 and no. 4 terminals should be the same element and the no. 2 and no. 3 terminals should be the other element. If this is correct put the 2 neutral wires, in any order, on terminals 1 and 2 and the active terminals on 3 and 4. This should work. You just have to check the correct element comes on when you operate the grill/oven controls.
Feb 18, 2011 | Smeg Ovens
Element for bottom fan forced oven wiring, I have a blue and green wire, should there be a third wire?
You should have 3 wires, the green is the earth. The other two would normally be blue and brown. If you have tried to change the element the missing one may have fallen back in or it could have been burnt off the element terminal and fallen down the back. Anyway you may have to remove the rear of the oven to locate it.
Feb 10, 2011 | Fisher and Paykel OS302SS, Stainless Steel...
What is the wire conection sequence
Hope this helps.
Dec 22, 2009 | Neff U1863 Double circotherm super...
I need to replace the bottom element in my oven
You need to check the heating element for continuity and the thermistor for continuity. Use an ohmmeter or multimeter to check. The element should not be any reading over 24 ohms for a 220-250V supply and not over 12 ohms for a 110Vac supply. A good tip is to take digital photos of the job before starting on removing and testing wiring etc so that you can refer back to it if you have to replace any items or forget which wires attach to any particular terminal etc.
To test and replace the element:
  1. Turning off the mains power to the oven.
  2. Remove the lower back panel. Fan assisted ovens will have a coiled 2 or 3 turn element around the outside of the fan.
  3. Remove the 2 power connectors to the grill element if one is fitted.
  4. Check the element resistance reading on the main oven heating element and not the grill element.
  5. The thermistor or fusible link is located on top of the oven cavity if fitted and has two wires attached to it - most likely to be red and black or both white wires.
  6. Remove the earthing wire to the main oven heating element screw terminal.
  7. Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your oven. Do this from inside the oven cavity itself.
  8. Refit the new element (make sure it has the same mounting screw holes as the one you want to remove) then secure it.
  9. Reconnect the earthing wire to the element screw post.
  10. Make sure that neither of the element tags touch the chassis - check with a continuity tester of ohm meter and adjust if required.
  11. Reconnect the power cables to the main oven heating element.
  12. Reconnect the power cables to the grill element if one is fitted.
  13. Reconnect the power and check that the element works correctly.
  14. Disconnect the mains power again and replace the rear panel(s).
  15. Reconnect the mains power and recheck that the oven, and if appropriate the grill, functions correctly.
Nov 14, 2009 | Ovens
Need to know wiring for element
i removed the wires from the fan and element and cant remember which colour wire goes where is thir a pictures for baumatie oven that i can use as a guide
Feb 20, 2009 | Ovens
Replacing heating element in a built in aeg fan oven
Simply pull the wires off, and replace onto new element, it does not matter which wire goes on the terminals, as they are common.
Plz rate my solution.
Thanks.
Jan 13, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Fisher & Pak\ykel element connection
white or red are phase, black or blue neutral
Mar 25, 2017 | Fisher and Paykel AeroTech Double OD302...
Hooking up new bake element
shouldnt make a difference your elemnt has only 2 terminals 1 wire to each
Mar 19, 2008 | GE JRS06SKSS Electric Single Oven
Neff U1421 Double circotherm Electric Oven Logo
1,657 people viewed this question
Top Neff Ovens Experts
Robert Lurer
Level 1 Expert
Paul Carew
Marvin
Marvin
Are you a Neff Oven Expert? Answer questions, earn points and help others
