Question about Samsung SCX 4623F - multifunction fax / copier / printer / scanner B/W
How to fix error #04-001
When i command to print/copy the error #04-001 pops up how do i fix it
Why is it I receive an error message "undefined" Offending Command: Operand Stack? What do I need to fix this?
This is an issue between the file you're trying to print and the printer not being able to read it correctly.
Try copying it and pasting it in a new document (preferrably different program) If that doesn't work, try to install and use another driver
Jan 20, 2015 | Xerox Phaser 6200N Laser Printer
Copier prints fine from computer. When asked to copy from a document placed on the glass, error message pops up"paper size detected is not supported. Job cancelled." The paper is the same we have...
If the copier is working fine as a printer using you computer as command , then nothing is wrong with the copier . But if you want to place a document on the glass and make copies , then you need to push on the copier machine the " start " button . You will be back on business .
Cood luck . Wilson
Feb 16, 2011 | Office Equipment & Supplies
Error messages and printing problems
Paper mismatch errors occur because the printer scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the printer, the printer reports a 'Paper size error'.
Try to adjust the printer and envolopee settings..
Regards,
polysandy
Apr 06, 2010 | HP PSC 1610 All-In-One InkJet Printer
Can't print new documents but keeps printing old documents
you acumulate a number of errors or print exe commands into the printer folder and it takes them first ... do not print anything ..but open the printer folder and /delete all errors and elder comands..
also is possible that into a previous print you set the wizard to print a number of multiple copies and do not have enough paper or so ...or just closed it before completing ..this will also make it print the elder command first ...so ...open the folder...( it can be opened from the tray system by right click and choose (tray =bottom right on task bar )...
Nov 07, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Sharp Al-800 H4 Error Code
Press : CLEAR key - INTERRUPT key - O - INTERRUPT key.
The copy quantity display goes off and the machine is ready to receive input of test command number.Enter the two digit number to select the test commands.The test command number entered will be displayed in the copy quantity display.Press the PRINT switch.The operation corresponding to the entered test command number will be performed.For the test command 13 and 14 since test commands 13,14 are used to clear the contents of the diagnostic status (U1,H3,H4)stored in the LSI,the diagnostic mode will be automatically canceled after completion of the test commands.
Jul 30, 2009 | Toshiba e-Studio120 Copier
Sharp AR-M160 , printing problem with OS: Windows 2000
Is the cable and the computer the same? sounds to me as if your not using a bidirectional cable
Apr 18, 2008 | Sharp AR-M160 Laser Printer
Samsung SCX 4623F - multifunction  fax / copier / printer / scanner   B/W Logo
213 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
