The outlet trips when I turn on the fan or light above the stove which shares the circuit and during no use at all
SOURCE: I have an electrical circuit in my home that
They put the GFI in line at the front, all the other plugs run off it. One of the other plugs, has lost ground, has lost neutral, a simple plug in tester will tell you this, find the fault, or,, you have a fluorescent bulb plugged into it. The gfi's are very sensitive, they snap at the drop of the barometer.
Testimonial: "Wow. Your reply was almost instant. Thank you. I wish they would have suggested that at my local home improvement store before now!"
SOURCE: What does the orange light
Has indicator always been ON?
Or did it suddenly turn ON recently?
Usually small indicator lights show that device is working, and has power.
Then when GFCI trips, the light goes off.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
You've lost a neutral connection at: one of the terminals somewhere; inside the outlet; broken strap between the neutral pads on the standard outlet; or the tester is providing an erroneous indication.
Does it read OK on the BOTH receptacles of the first outlet? Check the terminals that provide output on the first outlet and the LINE terminals of the GFCI . Bad at the first outlet? Check the input on the first outlet. Bad? Check splices between outlet and service panel and neutral connection at neutral bus bar inside panel. OK? Check the input to the GFCI - make sure on LINE terminals and proper polarity is observed.
Double check the line and load terminal screws of the GFCI outlet. Make sure that the power coming into the GFCI is connected to the LINE terminals. Be sure to connect the HOT and NEUTRAL wires to the proper LINE terminals. Neutral conductor (white) connects to the silver colored screws and hot (black or red) connects to the gold colored LINE screws. If you are sending power out to supply additional loads that are to be GFCI protected, the rules above apply - but connect to the LOAD screws.
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
(the following is from http://www.kellerstudio.de/repairfaq/sam/micfaq.htm#mictotdo)
If those are not the problems, then the main fuse is the most likely suspect for a totally dead microwave.
Remember, while you can do some repairs on you microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything
inside a microwave. If you want to do more yourself, let me know and I will point you in the direction of some good resources.
