SOURCE: PIXMA iP1300 printer is showing an error 5100
nope try this --
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
SOURCE: canon pixma ip1300
follow the link to download the driver
http://software.canon-europe.com/products/0010383.asp
select operating system and language.
Mark
SOURCE: canon pixma ip1300 installer
Go to this link http://software.canon-europe.com/products/0010383.asp, on this website Select the type of operating system you are using be it XP or Vista, Then under Available software for iP1300 select any of the software your want and start downloading it on your system which you will later install after downloading. Thanks
SOURCE: the canon pixma ip1300 was full of the ink
You need to reset your printer and replace the absorber.The absorber is on the bottom of the printer and you need to disassembly the hole printer to replace it.For reset the printer look this: http://tricks-collections.com/iptool-canon-printer/
Please dont forget to vote if you liked my answer
thanks
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? And what is your question?
