Question about Westinghouse Televison & Video
The hdmi setting doesent show on my tv
Some how the hdmi setting no longer shows
    Problem Solver:
  • 19 Answers
On lots if TVs if it does not detect an input signal it won't display that "channel" as an input option. I recommend check all the connections between your TV and your devices. if that doesn't appear to be the issue try unplugging all cables then reconnect everything(also unplugging devices from power). If that doesn't seem to fix it try replacing your HDMI cables if the cables went bad that could be the issue. If that still doesn't help you likely need to seek out a local TV repair service.
Posted on Jul 22, 2014
2 Suggested Answers
SOURCE: I have a 47" Visio 1080p. Tv is always set at hdmi
AV inputs are for standard analog video which is 480i. HDMI and Component inputs are the high definition inputs that run at either 1080i or 1080p You won't ever get 1080i or p through AV inputs.
Posted on Oct 23, 2012
casperaugust
Ian Dempsey
  • 85 Answers
SOURCE: HDMI doesn't show up as a source any longer
check hdmi cable itself
Posted on Dec 01, 2012
My ill dads Vizio VO320E showed classic symptoms of lightening damage so we purchased a new main board. Now the screen lights up but is showing pink and yellow horizontal stripes and some vertical sha
Mr. John either one of two things from start u have done right this is a common thing on flat sets hooked to Direct boxes by HDMI having surges come from box to set. The main board usually needs replacing, so either u received a bad board or u have multiple issues and possibly the T-CON board got surged from main board. This board is located above main and power in center at very top of screen. This will cause symptom that u are describing. Hope this helps.
Dec 08, 2014 | Vizio VO320E LCD TV
Samsung LV20M21CP - why it will no longer show sat tv?
Look for a button that says input or HDMI. That should scroll through the inputs available. Make sure the SAT receiver is on when you do this so the TV has a signal and may skip inputs with no signal.
Jul 29, 2014 | Samsung Televison & Video
Hdmi 6 and 7 do not work
HDMI does not like connections made with units powered and or on.
Try removing power from the units connected and the set for a while, reconnect them and then connect power to see what happens.
Most Sony sets have a reset but try the suggestion above first.
Dec 03, 2012 | Sony Grand Wega 50 in. Diagonal Class Full...
Hdmi wont connect to hdmi on laptop - shows lg screen on laptop with no model number but shows no signal on tv
Hi andy838,
I see that you LG LCD HDTV is giving you a No Signal message on the Screen.
see steps Below on finding out what will show video on your LCD HDTV.
* First make sure that the HDMI cable is connected to your Laptop to the HDTV LG.
* On your TV check your remote control and look for the input or Source Button, this will help you set your TV for the HDMI connection.
* Once set, turn your Laptop on and see if the HDTV will provide Video from the Laptop to your HDTV using HDMI.
* I believe that works right, now we have video still we need to set the Audio to work from you Laptop using HDMI to your HDTV.
* On your Laptop lower right side look for your speaker icon, right click on the speaker icon then select Playback Devices.
* Once you've selected Playback Devices you will see a window showing you a list of devices and the first one on the list will be you HDMI connection right click on it and select set as default device this will make your audio work on your HDMI to your TV.
* Once audio to HDMI is set and you want to go back to your Laptop just set the speakers as the default device this will set your speakers have the Audio working again on the Laptop.
I hope that this will help you regarding your concern.
Have a nice day,
mvincentc
Feb 25, 2011 | LG 42LC2D 42 in. LCD HDTV
No longer getting video feed through Home Theatre receiver
HDMI ports 5 and 6 on the back of tv no longer are working. (We had a series of thunder storms so don't know if that is how they got damaged or if it was something else) but moved HDMI input cable to HDMI port 4 on tv and everything is working again. Service call placed for warranty service on tv to repair bad ports.
Sep 14, 2009 | Sharp Televison & Video
Blank Screen using HDMI-DVI cable for PS3
Sounds like your LCD monitor isnt HD compatible.
Mar 17, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
New PS3 connected to HDMI: No picture/sound.
just hold down power button for a second beep then it will detect it.
Dec 16, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
