How do I get into menu to correct picture. Only screen remote puts up set up and nothing in list to correct picture. V-chip is block with access code which I don't know. Tried using 0711 twice but no good.No buttons on front to use for this problem. I have a Magnavox 24" TV/VCR/DVD set. And I don't have a manual.
Without a remote control, you can't access its Menu mode. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://homenol.blogspot.com/
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
SOURCE: setting up DVD/VCR
Depends how you have connected to the TV.
You will need to set your TV to the relevant socket you have connected the DVD/VCR into.
S-Video, Component , composite etc
These will be EXT 1 , EXT 2 or AV 1, AV 2 etc.
SOURCE: Service Menu Code
Its unlikely that the purple splotches can be cured from the service menu.
Assuming your TV is the Magnavox 20MC4304 combi, then the tv does not have a service code. There is an alternative though.
Details can be found in the service manual:
https://www.p4c.philips.com/cgi-bin/dcbint/sget?url=/mprdata/051111/0511110565_sma.zip&ofn=20mc4304_17.zip
SOURCE: need 13'' magnavox tv/dvd combo code for dish remote
To find the right code first click here.
Next click on the "Remote Controls" section.
Select the type of remote you have (based on the receiver model) to view the remote control users manual.
Hope this helps!
SOURCE: my magnavox model mwc20t6 keeps turning off after 10 to 20 secs
tv was working fine however when we moved it to another room it will not power on at all even using different plug ins
SOURCE: No TV "Select Source" Menu Option
Had the same problem and found on the back of the tv on the black box that the cable hooks to there is a plug at the top of that box on the left side came loose. If you slide that box to the right you can completely remove it from the tv. Reinstall it and make sure it's plugged in tight your tv setting should come back.
