I don't have a manual for this phone. How do you turn on caller id so that caller's # appears? It was working and now it isn't but don't know how to correct it. Please advise and thanks.
SOURCE: KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
SOURCE: How do you turn on caller ID on a Panasonic KX TGA181AL
Is your phone operated off a panasonic system? is so you need a caller id card. if not then you would need to inform your phone service provider that you need caller id. if you have caller id and you do have the caller id card you would need to get a hold of a panasonic tech who could turn on your c.id as long as it is being provided from your phone service and the card is installed.
SOURCE: caller ID/CLIP) not working in Panasonic cordless
Well if the phone has been bought abroad and being used in India you will face this problem. this is because of the format of transmitting the caller id info being different. In USA it is STF and in India it is DTMF. You need a convertor in the phone line which is DTMF to STF. IF you find onw in Delhi pl let me also know.
SOURCE: Purchased Panasonic KX-TG6431 with total 4
Since you are asking me how did i solve it without you giving me any solution or hint,how do you expect me to tell you .You want money for advising me then i also need the same if you want solution.
