Question about KitchenAid 9706529 Stand Mixer Worm Gear Kitchen Aid
Kitchen aid mixer only goes 1 speed
Doesn't advance from slow to fast stays at 1 speed
John Fink
    Champion:
  • KitchenAid Expert
  • 202 Answers
The number in your question (9706529) is for the worm gear.
What is the model Kitchenaid mixer you have?
Posted on Nov 22, 2014
5 Related Answers
Anonymous
SOURCE: Kitchen Aid Classic Mixer
I have this problem too -it is rather common if you search the web. There was a suggestion posted on this site about what to do. See http://www.fixya.com/support/t125253-mixer_leaking_oil I have also read about other people taking it to a Kitchen Aid repair place where they repacked the grease for about $45. I took mine apart and there is gobs of grease around the gears. Right now I am still trying to figure out what to do. I am going to have my father look at it to see what he thinks since he is good with motors. The Kitchen Aid web site says that the grease is FDA approved, so at least it's not going to kill you if a little gets in your food. Their suggestion is to take it out and run it for about 5 minutes at least once a week. They say it leaks if it is not used often enough. That logic doesn't make much sense to me, but you could try it. Mine seems to leak more when I run it because the grease heats up and liquifies more. I hope that helps. I'll let you know what happens with mine, once it's fixed. Lisa
Posted on Jan 19, 2007
Anonymous
  • 16 Answers
SOURCE: kitchen aid mixer stopped working
Nieu, I'm not sure what kind of mixer you have nor am I should what the one speed is.  In my case, I have KA 575 watt professional 6 model that would operate at only the highest speed regardless of setting. If your problem is similar to this, I would recommend that you first check the Hall Effect sensor which determines the mixer’s speed.  I bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My mixer worked as good as new! But I was curious to know if my original sensor was defective, so I put it back in mixer and again made sure all of the connections were tight. Guess what?  My original sensor also made my mixer work! There was absolutely nothing wrong with the original Hall Effect sensor except that the connection between the control board and sensor was not tight--unfortunately I didn't check the connection before I decided to buy the new sensor. My best guess is that the connection between the control board and the sensor probably loosens and comes undone over time from use and vibrations. Follow these steps:
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall Effect sensor looks like. BTW the part number is 9703312 for my model.
2.  You'll need a phillips head screwdriver to open up the mixer gear case cover.
3.  Make sure that the connection between the control board and sensor is absolutely tight and snug.
4.  Also, make sure that the orientation of the sensor is correct.  It's difficult to tell which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or down. After you've made the connection, run the mixer. If it still doesn't work, disconnect the sensor, reconnect it with the prongs facing the opposite direction and try it again.  I actually found the right sensor orientation through a little trial and error.  But by going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work if it were reconnected with correct orientation.
5.  This whole process probably takes less than 10-15 minutes to perform.
6.  Use your common sense and make sure to unplug the mixer before checking, connecting or disconnecting anything.
Posted on Dec 30, 2008
Anonymous
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. [email protected]. Let me know if it works.
Posted on Mar 21, 2009
Anonymous
  • 16 Answers
SOURCE: kitchenaid mixer speed
I would recommend that you first check the Hall Effect sensor which determines the mixer’s speed.  I had this exact problem and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My mixer worked as good as new! But I was curious to know if my original sensor was defective, so I put it back in mixer and again made sure all of the connections were snug and tight. Guess what?  My original sensor also made my mixer work!  There was nothing wrong with the original Hall Effect sensor except that the connection between the control board and sensor was not tight--unfortunately I didn't check the connection before I decided to buy another sensor. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations. To fix your problem:
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall Effect sensor looks like. BTW the part number is 9703312.
5.  This whole process probably takes about 10-15 minutes to perform.
6.  Finally, use your common sense and make sure to unplug the mixer before checking, connecting or disconnecting anything.
Anonymous
  • 135 Answers
SOURCE: I an looking for the intructions on my Kitchen Aid
Hi. Goto kitchenaid.com. Click on the Customer Care button, click on find manuals, in the search window, enter k45sswh. this page will show the operating manual and farther down the page the parts manual. Download both these files.
Go to mendingshed.com and locate their FREE kitchenaid service manual and download it. This manual will greatly assist you or a repair person should your mixer ever need repair.
A word of caution...Do not overload the mixer with too much bread or cookie dough or it will cause damage to the transmission. Use the recommended capacities found in the manual.
If this solution has assisted you, please rate it. Good luck! ricardok45
Posted on Apr 07, 2009
When I switch my mixer on it goes to full speed
If it is a Kitchen Aid mixer I would suspect the little pcb with 4 wires coming out of it under the rear cover at the top.
If it is not a Kitchen Aid you will need to supply more clues.
Mar 21, 2015 | Food Mixers
How do I fix my Kitchen Aid Professional 5 mixer that will not change speeds?
The speed adjustment is defective. You will likely need a service centre if you cannot open it up and find the problem and change any defective parts etc.
Nov 24, 2014 | KitchenAid KP50PS Professional 5 Series...
Kitchen aid hd professional mixer problems with speed controls
you need a new speed control board, easy fix about $35.00 for the part and an hour of your time, not even messy to do a total of six screws and four wire connections that clip on, several youtube step by step instruction videos available. parts available on ebay. let us know if this helps you
Jan 28, 2013 | KitchenAid Food Mixers
Who repairs kitchen aid mixers
Call the Kitchen Aid small appliance warranty office and they will tell you where the authorized repair person is that is close to you.
Dec 16, 2012 | KitchenAid K45SS Classic Stand Mixer
Speed control swich on Kenwood Titanium mixer
The switch on the titanium has a flimsy week point and is always breaking. This is a stupid economy by Kenwood when there is now so much good competition. Mine broke after only 6 months and Kenwood were less than helpful suggesting I took back to where I bought it - 500 miles away!! I wish I had bought a Kitchen Aid
Jul 08, 2012 | Kenwood Food Mixers
Kitchen Aid stand mixer just started going really fast at the lowest speed. I tried checking the sensor as some have suggested but is still goes really fast. It's only been used a few times. Is there...
Hi. Goto www.mendingshed.com , locate and download the free Kitchenaid Service Manual. This is a comprehensive manual and will help you with your task. You can also go to the Kitchenaid website and download the Parts Catalog for your mixer model.
If this solution has assisted you, please rate it. ricardok45.
Mar 10, 2009 | KitchenAid K45SS Classic Stand Mixer
MIXER WILL NOT RUN AFTER CLEAN/LUBE TEN YEAR SERVICE.
The speed control is a governor setup, it's purely on and off, as the weights on the motor shaft spin faster, they press against the contacts, and when they spin a fast enough speed, it turns off current to the motor, which makes it slow down, and current gets turned back on.  That way, you get a pretty consistent speed on a setting no matter whether it's lightly loaded or whipping something fairly heavy.  If you can turn the motor shaft by hand, then you don't have anything binding, but you might have gotten the speed control out of adjustment.  give it another go.
Sep 21, 2007 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid 9706529 Stand Mixer Worm Gear Kitchen Aid Logo
263 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Colin Stickland
Colin Stickland
Lee Hodgson
Lee Hodgson
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
