SOURCE: ALIGN CARTRIDGES
Unplug the printer, wait 30 second and plug it back in. Sometimes that resets it.
SOURCE: align cartridges error
This means one of the cartridges is defective, they cant align if they cant print. What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center. When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in. I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black.
Basically you align the cartridges and then swap them so the printer thinks they are still aligned.
The color still doesnt work and it is probably a defective color cartridge.
SOURCE: Printer hp 2210 always says Press Enter to Align
You press
Enter
, but the error message does not go away ? You have to bypass the cartridge alignment -
SOURCE: The printer says press enter to align cartridges.
Press the 'setup' and 'options' buttons at same time to override problem
