Computers & Internet Logo
A
Anonymous Posted on Jul 21, 2014
How do i stop file conversion mode in word - Word Microsoft Computers & Internet
james_dannn1
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 18 Answers
  • Posted on Jul 28, 2014
james_dannn1
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
18
Questions
0
Helped
3195
Points
20
Follow below steps to fix your problem.
1- Go on file > options > advanced >scroll all the way down to Compatibility options.
2- Now Select All Documents then under that "lay out this document as if created in: Select Microsoft Word version that you are using.
tip
AVCHD to FCP X-MTS/M2TS in 50/60 Progressive mode to FCP X for ProRes 422 (HQ)
HD Videos to Final Cut Pro X-Convert 1920x1080p 50/60 AVCHD files to ProRes for Final Cut Pro X Editing <br />Final Cut Pro X and AVCHD-Import 1080 60p HD Videos to ProRes FCP X Conversion <br /><br />The new Sony camcorders like Handycam HDR-CX360VE, CX700V, and Panasonic camcorders like HDC-TM900/HS900/SD900, TM700/HS700/SD700 support recording in 1920x1080/50p mode for PAL regions like UK, France, German, or 1920x1080/60p mode for NTSC regions like US, Canada. Even though <b>Final Cut Pro X</b> with the new UI is said to support AVCHD files natively, without transcoding to Apple ProRes, the 1920x1080p 50/60 AVCHD files still could not be detected/imported to FCP X. <br /><br />To edit the 1080/60p or 1080/50p <b>Camcorder AVCHD Videos to Final Cut Pro X</b>, the conversion from MTS/M2TS in 50/60 <b><a href="http://www.aunsoft.com/final-mate-mac/">Progressive mode to FCP X ProRes 422 (HQ)</a></b> or to Apple ProRes 422 is necessary. Aunsoft Final Mate for Mac is the recommended AVCHD to ProRes converter for Final Cut Pro X. It keeps better color than compressor. What's more, it can keep 50fps and 60fps in Apple ProRes. <br /><br />The guide below shows you how to <b><a href="http://1080p-converter.com/2011/07/avchd-to-fcp-x-mtsm2ts-in-5060-progressive-mode-to-fcp-x-for-prores-422-hq/">Convert and Edit 1920x1080p 50/60 AVCHD files to ProRes in Final Cut Pro X</a></b>. <br /><br />Step 1. <b>Import 1920x1080p 50/60 AVCHD files to Aunsoft Final Mate for Mac</b>. <br />Run Final Mate for Mac as the best <b><a href="http://www.aunsoft.com/final-mate-mac/">Final Cut Pro X and AVCHD</a></b>, which can import files from AVCHD camera and the separate .mts files on Mac hard drive. For files from camera, just use USB cable to connect camera to Mac, and you can select files to download to Final Mate for Mac with the wizard. Otherwise, go to the Resource tab, and click the Add file path button to browse the AVCHD folder with .mts or .m2ts clips. <br /><br />Step 2. Choose <b>AVCHD files to FCP X ProRes conversion</b>. <br />Select the files from the Camcorder tab or Resource tab, drag and drop to the Movies tab to create movie for conversion. You can choose the files to be joined as a movie, or create single movie for each file. In terms of joining as a movie, the files would play seamlessly. <br /> <br /><b>Step 3. Choose Apple ProRes 422 (HQ) with 50fps or 60fsp for FCP X.</b> <br />Click the Export button, and go to the third button for editing software. Choose Final Cut Pro &gt; Apple ProRes 422 (HQ)(*.mov) as the output format. Choose 1920x1080 from the drop-down list of the output video size, and choose 50 or 60 as frame rate according to your camera mode. <br /> <br />Wait for the conversion, and you can then import 1080 60p <b><a href="http://www.aunsoft.com/final-mate-mac/">HD videos to Final Cut Pro X</a></b> through the direct import and enjoy editing in FCP X. <br /><br /><b>Tips:</b> <br />If you face the problem that the resulting ProRes files have no video just sound in FCP X or QuickTime, just make sure you install the related ProRes codec for FCP X, or go to the guide: <b><a href="http://www.aunsoft.com/solve_no_video_problem_after_converting_avchd_to_apple_prores_for_fcp_x/">Solution to ProRes Video Issue in FCP X</a></b> on aunsoft.com.
tip
Flawlessly Convert SWF to FLV-Aunsoft SWF to FLV Conversion Our source video for...
Our source video for a specific project was an Adobe Captivate SWF file for showing people how to logon to our webinar. We needed to convert it to FLV, so it could be posted on our website. It's actually not easy to find one good SWF converter that could handle our original file after searching on Google for "SWF to FLV converter". In about fourth or fifth page on search results, I finally found one product that meets my expectation perfectly. It's called Aunsoft SWF Video Converter. It's not expensive and we were so happy that we could finish our project in time with the help of this converting tool.
With 10 stars meaning excellent, I'd give it a 10, for it is one of the very few SWF converters that actually worked with our SWF file and did as promised. If you have SWF files needed to be converted, Aunsoft SWF Converter is a worthy choice for its price. Besides, it offers not just FLV output, but also various video & audio formats for different purposes. You will find out more later.
I will show you how to use this SWF converter to convert SWF files to FLV files. I'm sure you will be impressed by its intuitive interface.
Step 1. Add SWF file(s).
Drag and drop swf files into the app if you want to convert them at one time to FLV format.
Step 2. Choose output format and specify destination folder.
You can see a variety of output options from Aunsoft SWF Converter. In my case, I simply choose "FLV-Flash Video Format(*.flv)", the first option in "Flash Video" catalog in "Profile" drop-down list. You can also check FLV H.264(*.flv) profile for FLV video with H.264 video codec and aac audio codec.
Step 3. Choose converting mode and start SWF to FLV conversion
Click convert button to start swf to flv conversion. You will be asked to choose converting mode, auto mode or manual mode. If your SWF file has no actionscript embedded, then auto mode is recommendable. Otherwise, please choose manual mode to realize complete conversion. If you choose auto mode, the program will start conversion and you can get in FLV file in seconds in your destination folder.
And if you choose manual mode to convert your swf file, you will see the following interface. The big preview window will not play your swf file until you click "Play and capture" to start conversion in manual mode. The moment the original file finishes playing in the big window, the conversion completes. And your FLV file will be ready in output folder.
on Jul 17, 2010 • Garden
What format of a video does ma797 mp3 play?
The player can ONLY play *.AVI files. For other formats, you need to use the converting tool included in the driver CD to convert them,
2) Use the AVI converter (1) Select “Program files”→“AVI Converter”on the Start menu to see the following window.9070010.jpg
2) Click "Add" button to display “Conversion Setting”window.
3) For the “Source File” field, specify the file that you want to convert by clicking the button on the right. For the “Target File Path” field, specify the destination where the converted file is saved. 11218e5.jpg
4) Be sure to select the correct resolution – 128x128 to match your player’s screen, otherwise the conversion may fail.
(5) Set the conversion quality in the Quality field and display mode in the Aspect Ratio filed. cfb0a43.jpg
(6) Click “Save”to save your setting. To convert another file, repeat the steps above. (7) Click “close”button to close the setting window.
How can i get videos on my mp4
There's an online manual for COBY mp-c7095 in pdf format:
http://www.cobyusa.com/files/manuals/MPC7095_MN.pdf
1. Use the video conversion software from the CD for adjusting
video to correct size before transferring to the player.
2. Check the system requirements for video conversion on page 34.
The conversion software in zip format can be downloaded with this link:
http://www.cobyusa.com/files/software/MTVVideoConverter_Ver1.12.11.zip
Once video is converted u could use Windows Media Player 11 for
transfers. A short guide on WMP11 for putting files onto the device:
1. Have WMP11 always on top for "drag and drop" usage
Right click in the head of the WMP11 page:
in Tools > Options... > Player : select "Keep the player on top ..."
Restore Down the size of the WMP11 screen and adjust the size on the
edge(s) as you require for your screen.
2. in [Library] mode: under Playlists "Create Playlist" e.g. "My Playlist"
and Enter: "My Playlist" is added on the right screen side.
3. Open your data maps and ad files by drag and drop method
onto the right saying "Drag items here"
4. when ready adding files in [Library] mode: "Save Playlist"
5. in [Sync] mode drag e.g. "My Playlist" under the connected device
and "Start Sync": wait until al files have synchronized: a message
will show up when you can disconnect the player.
tip
Best SWF to FLV Converter - Flawlessly Convert SWF to FLV Our source video for a...
Our source video for a specific project was an Adobe Captivate SWF file for showing people how to logon to our webinar. We needed to convert it to FLV, so it could be posted on our website. It's actually not easy to find one good SWF converter that could handle our original file after searching on Google for "SWF to FLV converter". In about fourth or fifth page on search results, I finally found one product that meets my expectation perfectly. It's called Aunsoft SWF Converter. It's not expensive and we were so happy that we could finish our project in time with the help of this converting tool.
on Jul 15, 2010 • Cameras
Raw file conversion stopped due to disk is full
Make sure, that the disc is not locked. If this does not work try dregging the files to your desktop, then convert them.
May 11, 2009 • Photography
1helpful
My video converter won't convert saome of my vids?
1. In Menu scroll down to Setup
2. In Setup scroll down to USB Mode
3. In USB Mode there are 2 settings MSC Mode & MTP Mode, check or highlight
MSC Mode. This enables the PC to recognize the player as a removable
Device or Drive.
4. Connect to PC via USB port/cable, the PC now reads the device as
MP-C70X5 (E:)
5. In WIN Explorer click “Open to View Files”, on display will be 6 .DIR folders
& a .xml file
6. Now launch the VideoConvert.exe (application file) located on the
installation disk.
7. Click Input Video button (Browse to the folder containing .avi files) & select
.avi file for .mtv conversion
(if you want to save the .mtv file to a different destination folder click the folder
icon to the right of the Video Output text box).
8. In Output Frame Size box check 176X144 (this is the max size for this
device).
9. In Output Frame Rate box check Sports Video.
10. The Output Audio Quality box defaults to Good.
11. Click Start Conversion button.
12. The saved .mtv file can now be copied to the device by simply dragging
from its destination folder or ctrl + C & ctrl + V to the MOVIE.DIR folder in
WIN Explorer as per step 5.
13 The .mtv file is now saved to the device ready for viewing, however there is
just one remaining small lissue which may a software glich or another hassle
with this player, because whilst playing video’s every 60 seconds in the
background a womans voice exclaims what sounds like “Weeee Gamble
whatsup with that.
ionfreez
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
